Sunroof shade
Date: 06/19/2019 01:33 pm
free transmissions
Date: 11/28/2019 10:21 am
Date: 07/11/2023 11:39 pm
1978 ford pinto carb
Date: 02/04/2018 06:09 pm
1977 Pinto for parts
Date: 10/10/2018 06:25 pm
Date: 12/09/2018 11:35 pm
Date: 04/15/2017 05:14 pm
1971 2.0 valve cover
Date: 01/25/2019 07:09 pm
Date: 08/22/2017 09:21 pm
  • Guests: 84
  • Total: 84
Can you say TRACTION!
Started by 78pinto, September 19, 2003, 10:39:58 PM
If you follow the time line the guy who brought this up - again - had one post.  Probably someone new, excited and just didn't see the date???
Tom
map351
I have a good used flux capacitor if any one wants to install it in there pinto! :lol:
73 2.3Turbo Pinto
6S1941 / 289 Slab Side
Pinto FiberGlass
Turbo Toy
I love it. Posts in 2003, 2004, 2005 and now resurrected in 2008. :showback:
CHEAPRACER
Umm, are we not noticing something here???
hint...  «  on: September 19, 2003, 10:39:58 PM »
LSXPINTO
Quote from: alkypinto on November 22, 2003, 11:11:43 AM
This car is a local racer at Milan and Norwalk. It does
this on every pass and doesnt hurt anything. Ive seen
it many times and it sure is fun to watch. My car used
to do this too when I had a 3 speed trans in it:
http://members.aol.com/RKRacing1/pintopg.html
What a blast it was to drive then!!!!!!!!
What kind of times is he running?
Scott
1979 Pinto LS1 76mm turbo project. th400 trans. 8.8 rear. 11inch 5 Lug on all four corners.  Hopefully it will be done spring 2009.
alkypinto
I spent a lot of time searching for a front spoiler that
looked like this one. However it was  no longer available and
many of the old glass companies went out of business. I had
an old one but it was really busted up (wheelstands). The
folks at MAS were kind enough to work with me on this. I
sent them my old busted up one and they matched it up
to the closest thing they had.
The front spoiler on my car is from MAS Racing Products in
St Paul MN, 612-644-6811. It is a P/N 1482 and I believe its
for an AMC Hornet or something? Its an all fiberglass spoiler.
Out of the box, its about 4 inches too narrow to fit the
Pinto front valance pan. So I split it in the center and made
a mold to add about 4" to the center of it. Fill the mold
with resin and hair and connect the pieces back together.
Once finished it matches the front valance pan perfectly!
Keep the wheelstands reasonable and it will last forever....
Rich
V8pinto_306_n2o
Alkypinto,
Where'd you get that front air dam?
PintoBro
Quote
Well not really! You see coilover shocks replace not only the shock absorber
but the spring also. And the leaf spring on a Pinto locates the rear end in
the car as well. So the only way to replace the whole EOM rear suspension
setup is replace the springs, shocks,and  location devices. The replacement
locations devices usually include a ladder bar or four link for front-rear
movement, and track bar, panhard, or wishbone for side-side movement.
This whole conversion update is shown on my website under the Y2K
upgrade link:
http://members.aol.com/RKRacing1/pinto2k.htm
But you really need a back half rear chassis to weld all this stuff into.
The OEM stamped sheet metal rear subframe isnt really a good foundation.
Hope that helps......
Rich
Well I was hoping that there was a bar that could be welded in that would serve as the top mount. I'd like to remove the current shock/helper spring setup and install a pair of adjustable coil over shocks. The bottom mounts would also serve as  wheelie bar mounts, as well as trailer tie downs. ;-)
Pintobro
71 Pinto 306 10.0:1 351w heads
Comp Cams: .554/.558 lift .294/.306 duration
Torquer II Intake - Holley 750 HP
Sepanek's Racing Transmissions C4 (Full Manual)
8" rear (4.62 spooled)
alkypinto
Quote from: PintoBro on August 15, 2004, 06:24:50 PM
Quote from: alkypinto on August 06, 2004, 10:36:33 AM
Sorry, leave off the "l" at the end.....
Now I know where I remember that car from! We chatted about chassis designs on Dragnet!
I got a question for you concerning coilover shocks. Is there a kit out there anywhere to convert a stock chassis to coilovers, without back halving the car? I have access to a set of coilover shocks for a decent price, and the only problem I see is the top mounts. The bottom mounts is an easy solution. Any recommendations on on a fix for the top mounts? Right now I have a set of helper springs  on the shocks to help keep the back end from squatting too much and wheel wells from rubbing the slicks. I'd sure like to install a set of coilover shocks so there would be a little more tuneability, untill I can afford to put a full chassis under it. Thanks in advance for any input you can provide.
upgrade link:
Rich
PintoBro
Pintobro
fordsbyjay
I remember that issue of Ford High Performance. That is an awsome car. Good job!
Cuts heal, chicks dig scars, but glory lasts forever!
alkypinto
PintoBro
I tried viewing this pager and got a message that it couldn't find that page. Has it been taken down, or renamed?
Pintobro
alkypinto
Underdog76
Yea that would probably smash the headers more than we did when we towed my dads 71 coupe 3000 miles up the Alcan Hwy, during construction season in Yukon, with less than 2 inches of clearance using only a towing hitch. It still runs great even with smashed headers!!
Fast as lightning, strong as thunder
fatheadinc
looks good but man talk about out of tune see kids that is why i want to run a four link instead of the ole easy fixer ladder bars .................poor car i bet it hurt when it came down!!!!!!!!!!!!!!!!!!!!!!!!
pinto brain child
74 runabout butcherd bbf project
victimized 71 sedan
sorry thats all i have. It is a wagon though!
SVOwagon
 :o   Looks like a wagon..I'd like to see more pics if you can get them.
SVOwagon
80 2.3 EFI Turbo Pinto Squire Wagon
91 Mustang LX 5.0 (93 Cobra clone project)
82 Mustang GT (built 460)
89 Mustang LX coupe (built 302)
83 Ranger
http://www.cardomain.com/ride/2167062
Underdog76
I bet the view is beautiful from up there ;D
Who, What, Where?
This was sent to me by a friend, no info on the car, sorry.  At first glance however you can tell he's got traction!
