Oddsnends
Date: 12/20/2016 10:52 am
Two 1978 Pinto Station Wagons
Date: 05/18/2025 03:10 pm
Date: 08/30/2021 03:20 pm
Clutch Fork
Date: 03/31/2018 09:12 pm
Hood Hinge rubber boots
Date: 09/28/2018 05:49 pm
Date: 02/18/2017 04:44 pm
Date: 07/20/2017 01:23 am
Date: 06/22/2017 07:19 am
  • Online today: 403
  • Guests: 391
  • Total: 391
roller cam?
Started by waldo786, April 08, 2014, 09:31:34 PM
The Ranger cam used two different roller rockers.  The earlier rockers fit the valve stem width of the Pinto motors.  The later rockers have too narrow of a guide slot to fit the Pinto valves.  These roller rockers also had two different ratios.  So, you have to match the roller rockers to the valves slot size, then you have to match cam to the rocker ratio.  Simplified just get the cam and the rockers from an early Ranger or Mustang.  Check for yourself, but I think the cut off year for the early rockers is 1993.
The worse case would be to use early rockers with a later cam (if you even can).  Lift would be very low.  Some have speculated using later rockers with an early cam for greater lift. But then you have the guide slot issue.  Discussion on the matter concluded that widening the slot would be difficult to follow the guide contours and have a hardened surface.  BTW, the Ranger/Mustang roller cam actually has a lower lift that a stock Pinto cam.  However, it is speculated that the lift rate (ramp speed) is faster and total volume passing through an open valve cycle is larger.
Just use the Ranger Roller Cam and have fun....The Cranes are for circle track, drag racing etc... Check with Turboford.org etc.
waldo786
Hello all,
    From what I understand a ranger roller cam will bolt into our heads with no problem.  I also found a crane dam that claims excellent low end torque.  I'm looking at making a nice driver out of my Pinto and have an offy 4 bbl intake with a holley 390 carb.  I also have the exhaust manifold from an 88 ranger.  Wondering if this cam will bolt right in as it is a replacement for the ranger roller, and what I might expect.  Also planning on adding stainless swirl polish valves as well.
http://www.cranecams.com/188-189.pdf
