Alloy Harmonic Balancer
Date: 07/10/2020 12:17 pm
1974 Ford Pinto
Date: 10/16/2017 10:45 am
Date: 02/22/2017 01:58 pm
windshield
Date: 04/14/2018 08:53 pm
Date: 01/21/2023 04:19 pm
Needed, 2.0 or 2.3 motors
Date: 09/30/2018 07:47 pm
Date: 03/27/2017 10:07 pm
Date: 08/09/2018 11:09 am
  • Online today: 489
  • Guests: 173
  • Total: 173
Manual Rack Ratio Question
Started by JohnW, March 28, 2014, 10:35:56 AM
Fill the hose, but just remember the power rack is a quicker steering rack and as such, will require a slight more effort to steer with out any power from the pump. No big deal. Try it and you can always go back to the pump. If the steering was too lite for your likeing, Speadway Motors has a control valve to alter the pressure.
poomwah
does the hose itself have to be full? or just top off the rack itself and then attach the "jumper" hose?
If by topping off you mean fill the hose too, what's the best way to to that?  T-fitting with a cap, like a heater hose flush kit?
JohnW
Great, I'll use my old rack for a core to get a rebuilt power one.
Quote from: JohnW on March 28, 2014, 06:17:36 PM
Running the power rack without any pressure/flow won't cause any harm? I'll probably just go that route then.
nope wont do any harm as long as you loop the 2 ports together
That's what we've done for years. FO MO CO told us to do that when Pintos were new. Still works.
JohnW
if you don't mind the hose and the extra weight of the power rack you can just make sure its topped off and loop the hose and have no problems.
JohnW
I want to buy a new manual rack to replace my power one for my 80 hatch. The power rack is 3 full turns of the wheel from lock-to-lock. Can I get a new manual one with the same ratio? What are the factory ratios for manual and power racks?
Or can I just hook the inlet and outlet together on a power rack?
