Wanted hood hinges
Date: 02/17/2020 05:30 pm
Date: 07/20/2017 01:23 am
1972 Rallye wagon rebuild
Date: 11/14/2020 07:31 pm
1971 Pinto Parting out
Date: 07/06/2018 01:11 pm
Date: 11/05/2016 09:03 pm
77 pinto cruz. wagon
Date: 06/15/2017 09:18 pm
Date: 10/31/2018 12:00 pm
1971-74 Various Pinto Parts
Date: 01/18/2020 03:44 pm
Date: 10/24/2019 01:45 pm
  • Online today: 2,399
  • Guests: 1036
  • Total: 1036
My Pinto...er....Bobcat....err....sumffin....lol
Started by Rob3865, March 08, 2014, 04:24:16 PM
Looks like you got it in time before it rusted away.
Rob3865
More pitchers.
Rob3865
More Bobcat porn. Along with removing the gas tank, one of the other first things I always do to an old car is strip the interior and remove the old carpet. It holds moisture over the years and surely has at least some surface rust there. Sho nuff, I wasn't surprised. The passenger front is the worst and has one very tiny pin hole. Other than that, it is just surface rust. I am very happy. Here are the pictures.
Rob3865
Got the gas tank and radiator to the radiator shop today. They said they could save them both. Said they would get the tank cleaned out and coated for 100 bucks. The radiator I had not noticed until I dropped it off, but it is a THREE core radiator. That will be plenty enough to cool the 5.0 IF it will fit. I am hoping with the extra short Explorer serpentine water pump that it will. I'll figure out something, even if it's wrong.
Rob3865
Nope leaving them stock. Actually, the P heads flow superior to the regular GT40 heads. I have flow charts on both around here somewhere. The Ps are supposedly the best flowing heads Ford ever made for the 302.....cept the boss heads. Not really critical though as I am building it stock. Should be all it needs.
derekrichmond15@yahoo.com
Its about time you got a car lol. I have started acquiring parts for my Pinto V8 swap I'm in the engine modification stage at the moment. The engine is a 351W that has been changed to a 408 Stroker it's almost a running engine lol so far the engine is twice the cost of a new Pinto!! The car is going to drive like a Squirrel every were but straight! Keep the pictures coming. Are you going to port and polish your heads they will follow just like GT40 heads!!
1977 408W stroked pinto
Rob3865
Got the gas tank out. It's not rusted out, but it has some THICK crud on the bottom. Got detergent soakin in it in the front yard. See what it looks like after a day or so. I will empty it out and throw a short length of chain in it and shake it violently and that will help clean it out. If it looks good after that, I will have it coated on the inside. Got the carburetor apart and soaking. I am gonna try to get it running as is because I need a car. Since the brakes do work, that's a little less work to do.
Very nice, solid-looking car!  Enjoy!
Dwayne :)
Rob3865
One more. It's amazingly solid. Disc brakes, power steering, factory air, but it's missing. 2.8 V6 auto. The brakes even work!
Rob3865
We got back just a little bit ago. Here is the ever elusive Bobcat. I am really excited.
Ugly Yellow had two loose 3/8" bolts holding the engine in. Stock Pinto trans mount, one bolt.
Only thing holding the engine up was the rack !
Side to side , the exhaust manifolds against the frame rails !
Saw an Old's in a Pinto one time. It was engine fender well to fender well. I asked him how he got the engine to fit. He told me he just lowered the engine in till it wouldn't go any farther and tie it down with a chain on each side, and drove it. I looked under it and sure enough, no motor mounts. TOP THAT ONE REEVES 1. Harff/harff/harff.
QuoteGosh, what a hot thread
652 (+) views......we are watching  ;D
I always watch V8 swap topics.
Learn new stuff all the time, as there are a thousand (or more) ways to do it.
Rob3865
Got the engine torn down last night. I have been a mechanic since 1974 and torn down a LOT of engines. It never ceases to amaze me when tearing down a newer year model engine like this 1999, how good a condition everything is in.
I don't know if that's from being fuel injected or the newer oil formulation or what. This engine had 174K miles on it, yet still has STRONG cross hatch in the cylinders, only a stain where the ridges would be. It will not even catch a fingernail. Almost NO witness marks on the camshaft lobes, no marks on the lifter rollers and no scores on the crankshaft. The piston skirts still have the knurls so strong on them that you do not have to use your fingernails to feel them. Absolutely amazing.
Would yall be interested in a basic valve job how to thread? I do as much of my own basic machine work as I can and if there's some interest, I will be glad to do it, since I am going to do the job anyway.
Sounds like it should be a real nice package when it's done.
Rob3865
I say stock, but technically, it is not. Ford never offered the Mustang 5.0 roller cam in the GT40P explorer engine. That is what I am going to do. Tear it down, freshen it up and put a used 5.0 Mustang GT stock roller cam in it. The Mustang cam is a little bigger than the Explorer cam. The Explorer GT40P engine has the best flowing heads Ford ever offered on the 302, besides the Boss 302, but they never offered that engine in the Mustang with the Mustang cam. Go figure. I will probably blueprint compression as high as I think pump gas around here can stand.....probably 9.5 or there abouts. Other than that, stock. Should be fun and reliable in a Bobcat with a T5 5 speed and 3.40 gears.
Yeah, Hooker is pricey alright but for a stocker I guess manifolds will work, the thought has been going through my head about converting if the 2.3 starts giving me trouble. I can relate about crawling under cars though, it's getting real old, LOL..
Rob3865
Hooker still makes headers, but they are not budget conscience. I am building this engine so mild, manifolds will not hold it back at all. I am not 100% sure on this, but I have read that the very manifolds I have on the engine in the above picture will fit in the Pinto/Bobcat chassis. If they do, they would certainly flow much better than the rustangII manifolds. But I have no direct experience so I cannot say for sure. I have had over 200 cars and most of them had headers. I want something permanent that will not rust and I don't have to crawl my old butt all over the ground fixin leaks. I am too old for that mess anymore.
Is there any headers that fit or do you have to use the cast iron manifolds??..
Rob3865
No Dianne, not at all. 74 and up it is a direct bolt in using the right parts. I did a 72 about 30 years ago. Had to clearance the firewall. But the 74 and up cars you don't have to do that. Makes you wonder why Ford didn't offer the 302 in the Pinto/Bobcat. Well......I know why. That would have stolen the rustang's thunder.
dianne
Vehicles:
- 1976 Mustang II mini-stock
- 1978 Mustang King Cobra II
- 1979 Ford Pinto Runabout
- 1986 Chevy K5 Blazer
- 1997 Suzuki Marauder
Rob3865
Just got back with this. A 1999 Explorer GT40P 5.0. From here on out known as the Bobcat motor.
Rob3865
Naw, I been turnin wrenches since 1974. Seen FWD and EFI come into vogue and worked on way more than I ever wanted to. IMHO, I think the melding of the car and computer was the biggest clusterfu%k that ever happened to the automobile. Takes the average joe's ability away from diagnosing his own car in his own driveway and saving himself some money. When it works, it's a good thing, but when it's on the fritz, it's a pile os sh!t. Jes sayin. No, this old white boy is stickin with a carburetor. Probably gonna run one of them new Demon 625 3 barrel carburetors. Read good things about them. For ignition I am just gonna run the good old Ford Duraspark.
Okay so where is the car ????? You have everything else....Rob...So are you going to put a EFI system in the car or are you going to back fit a carb and what ever distributor system you can find...
If your keeping the EFI check out the Aeromotive Phantom fuel system, it is an add on in tank fuel system" no welding or sumps needed", at about $500.00 or so it might be the cure all for EFI swaps fuel problems like I can't run the gas down past 1/4 tank etc. When I finally get my taxes done that's what I'm putting in my 2.3 Turbo Pinto...
Rob3865
Gosh, what a hot thread. lol Anyway, I got a 1999 GT40P Explorer engine today. Going to freshen it up with new rings and bearings, oil pump timing set and put the Mustang 5.0 roller cam in it. The Mustang cam is a little bigger than the Explorer cam. Going to pick the engine up probably Wednesday or Thursday and going to get the Bobcat Saturday. Pictures forthcoming.
Rob3865
A few pictures of my parts acquisitions.
Stock 5.0 carbureted intake. Blasted primed with VHT 2000* primer and painted dark Ford blue. Like the rest of the engine will be. Exhaust manifolds blasted and primed with VHT 2000* and painted with 2000* ceramic silver. And my big score I got today. An 8" Mustang II rear end with 3.40 gears. Very complete right down to E brake cables. Not pictured are my frame mounts, oil pan and pickup. I found some mounts and they are on the way. All this and no car yet. lol But it's comin.
Rob3865
Well, I had my decision narrowed to a 4 speed Pinto and an auto Bobcat. The Pinto is an everyday driver. The Bobcat will, run but needs fuel system work. No biggie. I have decided on the Bobcat. It's cheaper than the Pinto and the body is rock solid. It is a factory P/S, air and manual disc brake car but with an auto, so I will need standard transmission pedals for a 74 and up Bobcat/Pinto. If anybody has some, I am interested. I am really excited. I will have the bobcat here by April 15th. Will post pictures when I get it.
dianne
Vehicles:
