Deluxe Steering Wheel
Date: 10/16/2017 08:13 am
ENGINE COMPLETE 1971 PINTO
Date: 12/28/2017 03:55 pm
1975 Ford Pinto
Date: 01/13/2020 11:02 am
1978 ford pinto carb
Date: 02/04/2018 06:09 pm
Lower Alternator bracket
Date: 08/26/2017 05:11 pm
convert to stick
Date: 05/19/2018 09:26 pm
Date: 04/13/2017 04:56 am
rear hatch back louvers
Date: 04/18/2017 12:44 pm
2.3 pinto carb
Date: 08/18/2018 02:07 pm
  • Online today: 452
  • Guests: 231
  • Total: 231
Bad virbation
Started by dianne, March 06, 2014, 10:20:00 AM
dianne
NICE PINTO!!!!!!
I don't think the driveshaft was shortened and I haven't driven the car over 40 probably before this. Took it on the highway and it was brutal. I've made no changes to the drivetrain, but there has always been a vibration with the car.
I guess we'll start with the u-joints...
Vehicles:
- 1976 Mustang II mini-stock
- 1978 Mustang King Cobra II
- 1979 Ford Pinto Runabout
- 1986 Chevy K5 Blazer
- 1997 Suzuki Marauder
rramjet
Could be u-joints or the operating angle of the u-joints or too much run out in the drive shaft. The u-joints need to operate in the same plane with respect to each other within about 3 degrees. This shouldn't be a problem unless something has been done to the rear end or transmission to change the pinion angle with respect the the output end of the transmission.
I did have a similar situation on another car I have that had a shortened drive shaft. Who ever shortened the drive shaft did not get things straight and there was a too much run out, (wobble), causing vibrations at about 55 mph. Didn't notice a problem until I lowered the rear end gear ratio which put the vibrations in a noticeable speed range.
I would start by checking u-joints especially if the problem just started and is not associated with any other drive train changes you have made.
dianne
I have bad vibration over 30 miles an hour right now. I don't think it's the harmonic balancer (if it even has one) or anything like that. At 55 somewhat ok and speed limits here are 70, when I hit 60 to 65 I feel like the that pilot in Star Wars who shakes and blows up afterwards LOL
This was Dave's brownie and he said the driveshaft has been replaced with a Windstar or some aluminium driveshaft and was balanced. I can't get a hold of Dave right now. My mechanic, when I explained what was going on without explaining that new driveshaft replacement, thinks it might be the u-joints.
Could it be as simple as that or the actual driveshaft? Should I bring it to a place that does driveshafts or just replace the ujoints?
Any advise would be awesome!
Vehicles:
