1974 Ford Pinto Squire Wagon
Date: 05/30/2020 01:51 pm
Oil pan front sump style
Date: 01/10/2017 09:19 am
Date: 07/21/2017 11:49 am
Date: 03/30/2021 12:29 pm
1971 2.0 valve cover
Date: 01/25/2019 07:09 pm
Date: 05/15/2022 11:36 am
'80 Pinto Wagon
Date: 02/01/2018 05:20 pm
upholstery for bucket seats
Date: 10/30/2018 08:44 am
Date: 11/23/2017 05:44 pm
  • Online today: 306
  • Guests: 164
  • Total: 164
Anyone shoehorn a 4.6 in a Pinto?
Started by tintmaster, February 25, 2014, 10:35:12 PM
tintmaster
Yeah just enough for headers. Plus welding in sub-frame connectors.
C. Eugene Brown
FYI, Pinto unibody does not have really stiff front frame rails. Cutting fenderwell out in the wrong way can greatly weaken the entire 'box' that stiffens up the whole thing. The shock towers and further forward wells provide stiffness to locate the frame rails further as far as movement under load. The front radiator support structure reinforces all that to make the 'box'. That allows for lighter thickness front frame rails that cannot stand alone by themselves unlike a true full frame car that can.
You CAN cut there if it is done intelligently but you'd best have some ideas as to load bearing and things like that.
tintmaster
Yeah, it looks like I'm doing a 302. Thanks for all the replies.
C. Eugene Brown
A 4.6 is extremely wide. Creating a working oil pan & pickup should be interesting. The firewall, heater blower & master cylinder are gonna be in the way.
tintmaster
I read some specs on it. Its 28" wide and 26" tall. I plan on cutting inner fender wells to do custom headers. I just think it would be neat to open the hood and see peoples faces when they see it!!!
C. Eugene Brown
RSM
Not sure it would really fit without a major amount of work. The 4.6 is a fairly wide engine. It's a tight fit with a smallblock Ford or Chevy in one.
If running it pretty close to stock you would be lightyears ahead staying with a stock PCM and software. Megasquirt is fine but there is a lot of work tuning something like that in, even if they make one 'for that'.....................
tintmaster
Just pondering the idea of a all aluminum 4.6 to put in my '77. It weighs less than a 302, and can get a lot of HP out of it. I have access to 1 with an AOD for $650. Of course I'll have to get a stand alone management system. But I was thinking of using Megasquirt as they have 1 already for it!!
C. Eugene Brown
