2 liter blocks and heads
Date: 03/28/2018 09:58 am
Date: 10/31/2018 12:00 pm
1970-1973 Gas Tank/Blue Dash
Date: 02/07/2019 11:57 pm
Date: 10/03/2018 10:46 pm
1979 Pinto Rear Bumper
Date: 03/26/2021 03:26 pm
Date: 03/06/2017 01:19 am
Date: 08/03/2018 09:19 am
Windshield
Date: 01/15/2022 09:31 pm
1976 Squire wagon
Date: 09/12/2018 10:30 pm
  • Online today: 506
  • Guests: 247
  • Total: 247
Glass hatch
Started by yhalkeeiron, February 02, 2014, 12:42:47 AM
derekrichmond15@yahoo.com
I just did the swap to my 77 from a 80 doner car all was ez and gained rer defrost it all plugged into the wiring no splicing good luck!!
1977 408W stroked pinto
I think it should fit fine but a few holes may need drilled depending on the upper hinge & prop shocks. The seal should fit the 73
Just curious, what you say it will not fit?  I put a 79 bobcat full metal hatch on my 72 that I had years ago.  It bolted on just fine.  And other than having the holes for Mercury, it was the same.
Maybe it is because the gasket? The early cars, the gasket was glued in where the later ones had to slip over the pinch weld.  The glass hatch had a special gasket.  He might need to modify the lip to get it to fit.
That is the only think I can think of.  In my opinion, the rest of the pieces should bolt in.
RSM
yhalkeeiron
Does anybody know if a 79 glass hatch will fit on a 73 run about
Sent from my SPH-L710 using Tapatalk
