Pinto Fiber Glass Body Parts
Date: 01/06/2019 06:53 pm
71 72 front bumper brackets
Date: 06/10/2020 10:55 am
convert to stick
Date: 05/19/2018 09:26 pm
1974 Pinto Door Handles
Date: 03/07/2017 04:06 pm
Date: 02/18/2017 04:47 pm
1979 pinto
Date: 04/19/2018 02:02 am
Cruiser Dash Gauges
Date: 12/04/2016 11:50 am
78 wagon instrument y
Date: 04/30/2018 07:41 pm
1979 Pinto Rear Bumper
Date: 03/26/2021 03:26 pm
  • Total Topics: 16,268
  • Online today: 289
  • Guests: 222
  • Total: 222
woody wagon
Started by 79prostreet, February 01, 2014, 05:03:25 PM
79prostreet
Had a small window to test fit the dash with most the wiring done, so good so far. Ign. brain box & junctions behind glove box.
79prostreet
79prostreet
Well the day I had been looking for showed up last Friday, the boy and I took the hot rod off the rotisserie  and set it on the ground. Put fire to the beast on Saturday, what a moment that was!!!
79prostreet
79prostreet
Pinto5.0 you do win the'' wood in wagon''prize! Reeves1 I did use the thick tar style matte, found a slick way to apply it. Just make a lite cut threw the paper backing about inch and half from the starting edge and pull that pc. off, stick it down and work the rest of the paper off as you apply matte down. It did'nt hurt that most of the area was open and flat. After 4 years of this project I have started to install systems for the last time, fuel system in,trans cooler and lines in,motor w/ oil system(dry sump) in and primed, power steering in and filled and bled,all hoses and belts on. To tell you the truth I'm about half freaked out,for those of you that have never done a project like this you may not under stand that statement. After four years of on and off and on and off it's hard to comprehend it's being put on for the last time(all thats left of the Pinto is the shell and front frame rails/rad support).Still a lot of work to be done,but hope to start it in a few weeks. Bud  If you care to see some of the build pic's check out my gallery.
79prostreet
Is the mat the light weight stuff or the tar backed stuff ?
I used the self adhesive tar backed in my white car. Stuff was hard to deal with - the adhesive is really sticky stuff ! If it folded & touched tar/tar it was nearly impossible to separate !
Going with the light weight next time.
Quote from: 79prostreet on August 07, 2014, 08:59:17 PM
Wittsend, might need to put that under '' wood on wagon''. Some days you just got to do what you got to do to get the job done! Thank God for the bungee cord.
I win for wood "IN" wagon...... LOL
79prostreet
Spent some time on the hot rod,back half matted. Not to bad of a process, as always just takes time.
79prostreet
I love good old American ingenuity!
79prostreet
79prostreet
The other day I needed to haul two, 16 ft. 2 X 4's. This is my rendition of a Woodie Wagon. Those are 12 footers coming out the rear hatch too.
  Over the door handle, under the mirror. Bungee each end to follow the body contours. Staple on the flags. No problem. Well..., until I had to get my 57 year old body to do a NASCAR entry/exit.
79prostreet
A few more.
79prostreet
79prostreet
Found some time Sunday to work on the hot rod,pushed the wiring ball a little farther down the field. All wires are extended to the fuse/rely area and are ready to find their homes, that will be a large part of the project done. Received the stall converter and flex plate this week so it should not be to long till I the hot rod comes to life. What a day that will be!
79prostreet
79prostreet
I'm not quite sure how a wooden head liner would be with exhaust that's more than likely going to have a deep rumble, feel a head liner would absorb better.
79prostreet
QuoteA wooden head liner? now that would be different
Did that to a Ford van I had. Worked out great & looked real good.
79prostreet
Srt, go to my photo gallery and you will see what your looking for and more. Thanks Bud
79prostreet
how is the 4 link bushed at the connections with the car body?
79prostreet
Thanks Dianne,  I'm hopping the heat shield will keep the master cyl. from the header heat,only time will tell. I don't think the line lock or perportioning valve will have any trouble.
79prostreet
Just looks so awesome!
79prostreet
Had some time to work on the hot rod this week(month) and pushed the ball a little farther down the field. Headers wrapped & sealed (that's a fun job) exhaust built and hung. Trans came back so was able to finish lines, get pinion angle and drive shaft welded & balanced. Also Ralph was able to get back to wiring again(fell and broke his right wrist a few months a go),I get overwhelmed just looking a all those wires. Not Ralph, he wires firetrucks so he oddly enough enjoys it.
79prostreet
fordpower
What did you use for the panels.They look awesome .
79prostreet
Had a little more time this afternoon to install the rear end and brake set-up. The wood blocks are so I can run the nuts tight for mock-up w/o getting into the nylock part of the nut, when it's off and on and off and on it speeds things up for me. Bud
79prostreet
79prostreet
And the answer is--- 950cfm Holley 3bbl.  Did a few dyno pulls (950 dbl pumper  1050 and 3bbl)  my set-up liked the 3bbl.
79prostreet
Hmmmmm ok, either I've never seen one or it's been so long I don't remember it???..
79prostreet
This carb has not been changed in any way, not a very common Holley carb. And yes there is a choke in the picture. (large hole)
79prostreet
beaner
Ok I must be blind, I saw the choke area but I don't see a choke, looks to me like the choke horn has been milled off???.. Of course an 1850 can look like that too if you change bowls..
79prostreet
both those attempts are not correct, a clue for me is the choke .
79prostreet
