Tire needed p185/80r13
Date: 12/31/2017 09:08 pm
1973 Pinto hatchback for sale
Date: 11/13/2023 11:30 am
79-80 full glass hatch
Date: 01/04/2017 04:04 am
1974 Wiring diagram free
Date: 10/27/2019 06:56 pm
1977 Pinto for parts
Date: 10/10/2018 06:25 pm
Date: 08/09/2018 07:49 am
Date: 10/31/2018 12:00 pm
Date: 04/25/2017 12:17 pm
1974 Ford Pinto Squire Wagon
Date: 05/30/2020 01:51 pm
  • Online today: 1,293
  • Guests: 1160
  • Total: 1160
boring engine block
Started by tim1223, June 27, 2005, 02:02:46 PM
tim1223
Thanks for the info pintony.  Now to find a turbo 2.3l.  I'm going to build up a back up motor,  because I have enough parts sitting around to do so.  That way I can minimize the time that my Pinto is off the road.
Hey Tim,
I would say Yes!!!
Somebody back me up> ;D
The turbo head and the oval port head from a PINTO both use the D-combustion chamber.
From pintony
tim1223
   Can I use rebuilt (non-turbo) head on a turbo block?
billnall
You will not know until you pull the head and look, but my 77 Pinto Wagon came with .020 pistons from factory.
The way I understand it if a new block had a casting flaw in the cylinder wall they would bore it out .020 and put it in the new car rather than scrap it. The size will be stamped on top of the pistons if it is oversize.
Ford Parts Man
tim1223
   I didn't know that.  Did any Pintos come with the oversized pistons?  Do you know the block #'s or are they the same?
billnall
Some 2.3's came stock with 0.020 oversize pistons.
Ford Parts Man
Hey Tim,
Find a 2.3 turbo block 85-89 they almost never have wear on them.
from pintony
tim1223
Hello,  how many miles does a stock 2.3l get on it before they have to be bored?  I have some new standard pistons that I would like to use IF possible.  I know that there are many factors that have to be considered.  I was wondering how many miles other blocks have before they need machine work done to there block.  Thanks Tim
