Date: 01/18/2017 05:35 pm
TWM Intake
Date: 08/15/2018 08:20 pm
Date: 07/30/2018 04:32 pm
1976 Pinto runabout
Date: 03/28/2017 08:14 pm
1975 mercury bobcat
Date: 08/14/2018 03:40 pm
Wanted 73 pinto squire wagon
Date: 05/09/2020 11:59 am
77 Wagon rear hatch
Date: 12/04/2019 05:57 am
$300 Pinto for sale
Date: 04/19/2017 10:24 am
Mustang II C4 Transmission
Date: 07/28/2017 06:26 am
  • Online today: 802
  • Guests: 235
  • Total: 235
Looking for carb, intake and exhaust upgrades on lightly modified 2.3 motor
Started by CRUISEWAGON77, January 25, 2014, 01:23:23 AM
To work they must be ported and you must use an adapter for the carb. Go to http://www.bo-port.com and look under intakes for a ported intake. With out the porting they are worse than the stock intake. You can make the stock intake work better by playing with the jets. Example is smaller jet for the center runners and bigger jet for the outside two runners.
CRUISEWAGON77
What about an efi intake, those supposedly flow better too right?
Bought brand new by my Dad, 36yr OLD STOCK WAGON.  CAME AS YOU SEE IT, soon to have some bolt on goodies.
The # is cast onto the side of the carb. The carbs were used on 260 to 390 Fords. Go to http://www.carburetion.com/ford2v.htm Go down to the bottom of the page and it will show what the CFM is for each number. I've cut / welded / added to / taken from / and nothing helped on the intakes. When I did one of the mods, the engine idled so bad it sounded like a fuel dragester. But on the track it ran just like it did before the mod. If you use a 2100 carb you will be able to run a smaller jet for the two inside runners. 1.08 / 1.14 / 1.21 are the size carbs that should work out very nice. Go to 4m.net to read more. Go to mini stock tech at the bottom of the page. Those people love the 2100 carbs.
CRUISEWAGON77
Thanks for the replies.
On those 2100 carbs, what do they normally come on and where is the number stamped?  Would doing anything to the stock intake help for flow too?
On the manifolds, I've heard that too.  Does anyone have any say that has been running one?  Did they notice an improvement?
waldo786
I plan on running a holley 390 cfm, an offenhauser dual port intake, racer walsh stage 1 roller cam with stock stainless steel swirl port valves and the exhaust manifold from a late 80's ranger. (I'm told these flow better).  You could use of the mid 90's ranger headers but I believe they need some modification.  I'm excited to see how this setup works.  I want a nice engine I could use as a daily driver tha is not overkill as I do not plan on racing it so I decided against larger valves and head work.  I do also have a large open air cleaner assembly too.
First of all look at "horsepower curves" below your posting. If you are cheap like me, get a mid 90's 2.3L ranger header. Then get a Motorcraft / Autolite carb in the size 1.08 to 1.21. Size is stamped on the carb. They all are 2100 carbs that come in several CFM sizes. They will bolt right up to your intake after you remove the 32/38 adapter. The carbs are in every junk in the country as they were on Ford car until they went to EFI. Parts are easy to get also. Hope this helps.
CRUISEWAGON77
I have searched a lot about all the different options out there for go fast bolt ons, but most are based on stock engines.  I have a lightly build 2.3 in my original 77' Cruisewagon that we'd like to keep stock as it's been in the family for 37 years now.  The motor has been bored .30 over, larger intake valves, port matched head and an rv cam (comp cams 244/415 with 219dur @ 50deg).  I'd like to hear options on what header (ranger/mustang), intake and carb.  Like I said, I know this has been beaten to death, but I figured my motor tweaks may call for more.
Eric
