1977 Pinto Cruizin Wagon
Date: 08/07/2023 02:52 pm
Brake rotors
Date: 03/24/2017 09:02 pm
Date: 05/21/2019 11:50 am
Date: 12/10/2016 04:11 pm
Date: 09/21/2018 11:35 am
Date: 01/19/2020 09:06 am
need 1978 pinto guage cluster
Date: 03/07/2021 07:35 am
Lower Alternator bracket
Date: 08/26/2017 05:11 pm
Date: 08/03/2017 07:40 pm
  • Online today: 382
  • Guests: 370
  • Total: 370
Spring rates for corner carver/daily driver & new leaf spring advice
Started by JohnW, January 15, 2014, 10:20:06 PM
JohnW
My leafs look pretty rusty and thin in the middle where the isolator is, that's the main reason I wanted to order new ones. I've snapped them in 2 trucks, really don't feel like breaking springs in my car. Thanks for the info.
Jerry merrill
I've tried them all over the last 40 years. The 3" is not the drop but the free arch. When you lay the spring on its side, if you draw a line from the center of the front eye to the center of the rear eye, and then measure from that line to the spring, that is the arch. Stock will be 4" to 5". What you want is 3", which will lower the rear end 1" to 2". You can have your springs de arched much cheaper than new Speedway ones. And if you want stiffer, just add a leaf. At the front, just use cut down stock or wagon coils. Doesn't take much more than 1/4 to 1/2 coils to be removed. This will put you down as low as you will want to go on the street. If you need more use blocks at the rear and trim on the coils some more. Remember to go easy on the front or you'll be buyings more coils. When you get this done, get your self some KYB gas shocks along with a 1" front bar. Alinement for the street if your smart enough to get some 7" wide wheels, s/b 1deg caster / 0deg camber / 1/8" tow in. You can go up to 2 deg neg camber but tire wear will be greater. Now you should be set to kick butt with those ricers any day. This is the set up I used in SCCA to win races over 40 years. Try it cause your going to like it. I used this set up on the track and the street with no strange handling ever. Hope this helps. If you need more, PM me as we have a group of corner carvers that trade ideas all the time.
JohnW
So from what I could find searching on here, stock leaf spring rates in a Pinto hatch would be about 80lb?
Speedway's got the AFCO 104 and 138lb as well as Landrums in 100, 125, and 150. I read the Landrums are a 3" drop and I don't want to lower my car that much, and the weight ratings are really low (only like 2100lb for the 150lb springs?!). The AFCOs are stock height, right? I'm leaning towards the 104 as they should be bit stiffer than stock. Anyone have experience running either the 104s or 138s on the street? I'm thinking the 138lb ones might be too harsh. I want it to do well in the windy mountain roads throughout the state, but I don't want it to be horribly uncomfortable since my Pinto is what I drive for 90% of the spring, summer, and fall.
There's also the Calvert mono-leafs, but those are 200 or 225lb springs and I'm guessing that would be way too high, plus they're a little more expensive.
I also believe the front coils are around 200lb? I'm going to be switching to coilovers once I buy new front control arms.
My car is an '80 4cyl hatchback that I'm turbo swapping.
