Date: 05/18/2020 10:22 pm
Date: 11/05/2016 09:03 pm
2 Station Wagons for sale
Date: 04/20/2018 11:10 am
Date: 08/30/2021 03:20 pm
6.6.75 carrier
Date: 02/14/2018 06:47 am
Date: 12/13/2016 10:25 am
2.0 Cyl Head1973
Date: 11/29/2018 12:51 pm
Date: 08/20/2017 01:34 pm
1978 pinto grill
Date: 07/24/2018 02:18 pm
  • Online today: 452
Horsepower curves ???
Started by bombi, January 13, 2014, 03:03:13 PM
I don't know what your picture is of, but I have two EFI intakes in front of me and both have four holes below the carb. Explain  please.
slowride
The 38/38 is one half of the plan. The other half is the modified EFI intake. The gray areas are where the dividers are milled out to create a dual plane intake (1&4, 2&3). Since the 38/38 is tunable for each barrel (and plane), it should be miles ahead of a stock carb intake. The black circles are the barrels. Mill a small equalizer slot in the divider between the planes and it should help smooth the intake pulses and give a better idle signal.
Theoretically of course ;D
ToniJ1960
Quote from: dick1172762 on January 24, 2014, 05:12:38 PM
The stock intake is bad but the problem is the carb and the intake. Put a 38/38 Weber on the stock intake and the engine will come alive. Why you ask? On the 38/38 both barrels work together at all times, not just when your foot is in it. The GT-Pinto class in SCCA requires a stock intake with a 500 Holley two barrel carb. Those Pintos run as fast as new Vetts on a road race track. I saw one clocked at 145MPH at Summit Point race track. Cheap way to fix that "bad stock intake".
Now look I lpve my Pinto and my Corvette, but be rel ok. Maybe an 84 like mine, but not a new Corvette :)
Clydesdale80
I agree, the stock intake is terrible for fuel distribution.  This simulation had a long, approximately equal length runner intake with a 390cfm four bbl.  I have an offenhauser dualport that I plan to start with on my engine but eventually i'd like to make something from scratch.
Bought a 1978 hatchback to be my first car.
slowride
Bigger valves will give it more RPM potential (if flow is holding it back), but my feelings are the crappy A/F distribution is holding it back far more. These intakes are notorious for running #2 & 3 fat and 1 & 4 lean. On top of that, you open a secondary (right over the #2 & 3 runners) and it compounds the problem.
I run an auto and it's a bit deceiving having the torque multiplication at low RPM and having it go away in the mid-range. Give me just a bit more mid and I'll forget about more RPM.
Clydesdale80
to get that long flat torque curve I basically set everything up for low rpm torque and then added big valves which made the torque hold on for another couple thousand rpm.  If I can build an engine thats even close to that graph it should be very drivable and fun, especially with a T-5 behind it.
slowride
If I can get my hands on a turbo intake for a reasonable price, I'll be modifying it to be a dual plane, and run a 38 Weber. While I have made the wagon launch hard, the mid-range torque (even with the Comp Cam I picked) is what makes this car "slow". With the runner layout on the stock intake, I'm just beating my head against the wall (and wasting gas) with a useless secondary on the 5200.
Clydesdale80
I've been playing with that program more and what it shows would make me agree with Slowride.  It seems that the 2.3 (atleast how CamQuest models it) responds to some fairly basic mods with a surprising increase in torque.  Exhaust and intake gains are substantial.  I ran it with my planned build and it gave me this...
This is a more involved n/a 10:1 build with porting/valvework, headers, 4bbl, and stock cam.  I feel that the numbers it gives are probably quite optimistic but I also think it shows that there is potential gains.
slowride
Quote from: bombi on January 23, 2014, 01:31:52 PM
LOL.....
just looking to see if replacing the torque converter in will help in this application, and what stall speed to go with...
thanks.
I've been looking at another TC, but not necessarily for stall. Believe it or not, the tweaks on the 2.3 make it launch hard. I just don't want it coming apart at a stoplight....
bombi
LOL.....
thanks.
slowride
Nothing constructive to add, but almost spit out my coffee when I saw the subject line....... ??? Pinto and horsepower aren't normally synonymous.
And that was when NEW! Buy a ricer if you want hp. Buy a Pinto if you want lasting value and style. When was the last time you saw a 71/80 ricer? Oh! I forgot, that they didn't rust proof them. Oh well, live and learn so they say.
That's close when power drag is figured in. Old school gross measurements had around 100 hp at crank and 125 ft.lbs. torque..............
bombi
thanks for taking the time, every little bit helps.
Clydesdale80
This is what CamQuest comes up with if i put in everthing as close to stock as I can.  It must be in the ballpark because the peaks I found online said horsepower  88 @ 4800 RPM,  torque  118 @ 2100 RPM.  Just drop everything a little for smog equipment. Graph starts at 1000rpm,  each vertical line is another 1000rpm, each horizontal line is 10hp/10ft-lbs
This is at best an estimation, someone else can probably give you a better answer.
bombi
Anyone have any horsepower curves for a 1979 Ford Pinto 2.3liter or similar ?
