2.0 Cyl Head1973
Date: 11/29/2018 12:51 pm
1980 cruising wagon ralley
Date: 07/12/2019 01:41 pm
Date: 11/29/2018 10:26 am
Date: 09/12/2018 12:33 pm
Weber dcoe intake 2.0
Date: 08/01/2018 01:09 pm
2.3 pinto carb
Date: 08/18/2018 02:07 pm
Windshield
Date: 01/15/2022 09:31 pm
1976 pinto for sale
Date: 01/12/2017 02:08 pm
73 Caliper Retaining Key
Date: 10/28/2021 07:49 am
  • Online today: 587
  • Guests: 344
  • Total: 344
Check Thermostat and Full Coolant Flush
Started by cgbdrummer, January 02, 2014, 11:49:16 PM
cgbdrummer
cgbdrummer
Ok great  thanks so much man. But I looked where you were talking about and I didn't see anywhere where I could turn it on or off ( ill post a picture). Also, it's about 25f outside and I drove my car down the road for a few minutes and the bottom radiator hose is warm but the top one is cold, it wasn't warm at all. So doesn't that mean my thermostat is stuck closed?
jtowndown
make sure the vacuum line going to the heater valve is on. If it is make sure the the valve is working. btw the heater valve is located on passenger side of engine bay pretty close to the  firewall, one of your heater hoses goes through it. if your going to drain coolant to do flush i would take the valve of clean it and test it with a vacuum game. Also if you have a fail safe thermostat it could be stuck open. I will take pictures and take you step by step and should post it after work. maybe saturday...
cgbdrummer
The heat in my 79' has not been getting very hot, even after warming up the car for about 10 minutes. I don't know if it is the thermostat or not but I was wanting to check it myself, but I have no idea how. Also, while I'm dealing with the heating and cooling, I would like to do a full coolant flush, which includes the radiator and heater core so that I can get the most out of my heater and my engine. I've never done anything like this but I've read and watched a lot of videos about it on the internet so I was wondering if anyone could help me, step by step, check or replace my thermostat and flush out my coolant system. I know it is a lot to ask for but I would really appreciate it. Thanks!
