Date: 09/26/2019 05:31 pm
73 Runabout
Date: 11/20/2017 03:19 pm
Date: 02/18/2017 04:41 pm
Date: 05/22/2018 02:27 pm
pinto floor mats??
Date: 01/11/2017 07:27 am
Date: 03/05/2017 03:27 pm
Pinto Fiber Glass Body Parts
Date: 01/06/2019 06:53 pm
SVO SWAP
Date: 03/15/2018 03:12 am
1972 pinto grill
Date: 02/27/2018 12:13 am
  • Online today: 587
  • Guests: 275
  • Total: 275
Anyone know about this Edelbrock set-up?
Started by rramjet, December 10, 2013, 11:28:38 AM
1oldtimer
Quote from: L.D on December 17, 2013, 02:23:58 PM
I have a few intakes on the 2.0 the pony ram, the esslinger 4 mukuni bike carbs ,the holley 390 4 barrel the latter two where on a built 2.0 with an esslinger head and a big crane cam flat tops etc etc etc. For a stock motor the header and a holley 350 should work fine .
Can you give a review of each of them, since you have first hand info. I have the Edelbrock set-up and was going to run it on a slightly modded pinto 2.0 ( cam, headers and slight head work). It's going to be a driver (model A with a T5), but would like some more power.
It seems like the stock pinto 2.0 with a holley 350 is the best way to go for a '73 2.0 ? how about a large base Rochester 2 jet (350-425 cfm)
'72 2.0 in a '28 Ford.
Thanks for the site good stuff there, yeah it is a tad pricey but the pic will come in handy.
Gotcha on the spacer, makes sense with the stock intake should work ok on the EFI lower.
Part already made but a bit pricey..............1 inch thick
http://www.powerbyace.com/Catalog%20page/Ford%202_3L%20SOHC.htm
Go down maybe 1/3 page to first listing under 'induction' section. Part #5001.
I may be the one that mentioned EGR spacer not good. I meant in the context of using it on a stock 2.3 manifold and too close to floor in that case, also I don't care for all the opening cutout under it. Space it up a bit and most likely fine. My point was that the turning radius off the bottom of it to go sideways was crap in the stock useage. With the vertical column there mixture would have a tendency from inertia to keep going straight and smack into the floor before turning. No room to turn.
Thanks I'll make a note of that, shouldn't be hard to do.
You need to kept in mine that you will need as much pendulum as possible. Get the carb as high as you can to do this. You may have to mill out part of the 4 ports to get a pendulum. I've seen pictures of intakes with over 1" removed. You still will need to blend the ports.
Oh ok cool, I thought it was mentioned somewhere that the EGR spacer was not a good thing maybe I misunderstood, that makes it even easier.
The EGR spacer will work just fine. Just put on top of your adapter. You can saw off the big vacuum connection and plug it with a pipe plug. That way every thing will bolt up just like the stock intake. And look stock.
Mine has the EGR spacer so I could just use a piece of 1" aluminum to make an adapter and blend it all in.
Quote from: 74 PintoWagon on December 21, 2013, 10:07:22 AM
Thanks for the info, that one makes more sense super easy to make an adapter for it too, that's the one I'll be looking for.
Here's what I an going to do. I'll put a 3/8" aluminum plate cut to fit on top of the intake. Then I'll put the entire Holey / Weber mount off of the 2.3 Pinto intake on top of the 3/8" plate. This will be necessary because the carb need to be at least 1" above the EFI intake. 2" would be even better if there is enough clearance. Easy mod but you MUST blend the ports of the EFI intake.
WAY TO GO AMC 49!!!! Good information and even better pictures. There one on E-bay for $54 shipped free. I payed $40 each 10 years ago for the two I have. Keep up the good work and keep the tech information coming. We need it!
NO WAY. I'll try to send you a picture. Computer is acting up.
'He told me that when they tested 2.3's on a dyno, that it made no difference what carb they used as the HP stayed the same.'
I heard similar to same thing, that if you modded the stock carb that you didn't mod hardly at all before the manifold itself became the limiting factor rather than carb. After better flowing aircleaner, remove one choke plate to run one only, clean up throttle shaft of screws sticking out, past that and wasted effort until the manifold was ditched. Further mods showed on carb alone but put carb on manifold and nothing, it disappeared. Manifold sucked and hard to fix as made with much thinner casting thickness than earlier stuff; any heavy grinding where you need it and hit water really quick. I myself thought to lengthen the two short ports but then that killed entry from above, just an all around fudged up part there. What with the EGR plate just metal everywhere you did not want it and hollow spots to be filled everywhere. Never seen a part that needed so much work, you'd be a freaking' design engineer by the time you were done.
Cool thanks, adapter is no biggie I can whip one of them up easy enough if I have to, I'm just gonna use the Holley/Weber on this one for the mileage and keep the wife happy, lol..
Only difference I've ever seen, is that some of them have a hole about 3/8" in diameter right in the center of the flange where the 4 holes (ports) come together. No big deal because you can plug it several different ways. And if you don't go wild on blending the ports most any thing will work. To use the stock carb, you will have to use a adapter on top of the adapter as it is made for a Holley 350 / 500 two barrel carb. I THINK you can use the stock part that your Holley / Weber bolts onto. Never tried that but it should work. That's what I'm planning to do on my 80 Pinto (I hope). Stock carb is plenty big for the street and will improve mileage too.
That settles it, I'm going with the EFI for sure.
BTW, is there a particular year or are they all the same?..
The stock 2.3 intake was made the way it is for one reason, and only one reason. CHEAP to cast as all the runners are straight with no turns. There are way to make it work, but I never found them. I tried changing the angle of the ports under the carb, I tried putting a divider to block the ports from feeding each other. Every thing I did made it run worse, and it idled like a top fuel dragster. I then called a friend at Ford and asked him what to do next. He told me that when they tested 2.3's on a dyno, that it made no difference what carb they used as the HP stayed the same. We also tried screen wire wadded up under the carb(1963 trick on 427 Fords), but no improvement. Plain and simple, get a EFI lower intake and you'll see a big improvement in both idle and HP. Worked for me.
Looks like the EFI intake is the practical way to go I guess, think I'll start looking for one of those. Sounds like the 2.3 intake was a real boner on Ford's part.
I never ran the EFI lower but that would've been my next move as well, I looked at them back in the day and liked what I saw.
The 2.3 head is designed like the manifold continued into the head and then someone cut the manifold in two at the head surface. 4 different ports on the 2.3 and calculated to make even flow impossible. The outer port angle is ridiculous and how Ford did that and thought it was good is beyond me. The actual 2.3 intake not so much a manifold as a dumping ground. Fuel dumped there and just happens to go into the cylinders, pretty hilarious. Who cares which one?
Ok, just looked in the shop manual at both heads and I see the difference now, don't look like it would be hard to make an adapter and if the 2.0 intake is that good, seems like it would be worth the effort to make one??, but if the EFI intake is just as good I guess that would be the easiest route.
Sounds like you used a dual Weber intake. We did that (long time ago in a land far away) and we had all 4 plug wires come out sideways. Much better than the S shape Weber intake for the 2.3. The EFI lower intake is the way to go, and really easy. I plug the injector holes with pipe plugs, do a little porting where the carb goes, and buy or make an adapter to go between the intake and the carb. The one I'm doing now is the same except I'm going to TRY to use a stock cab(Holley / Weber) for the street. May have to make both barrels work together. The D port intake bolted onto an oval port head works very well. So easy a caveman could do it.
You match the adapter plate's holes to the 2.0 intake rather than the 2.3 head port. That allows the round port to fall very close to the round inner 2.3 ports and it falls also at the round area of the outer two oval ones. Then only very light matchup needed to make it work, you let the rest of the mismatch fall where it may and it works great, engine never sees the ugly there. I used 1/2" aluminum plate on mine and no mill facing of the surface that I fitted to the 2.0 intake, then after adapter pulled up tight on a 2.0 gasket I had the whole thing refaced flat at head surface and since then treat the double part as one and inseparable.  Use 2.3 gasket on the outboard. Need to use a longer neck oil pressure switch and careful around the distributor. I had to make up a custom cap that had two plug wires coming out of the side of cap lower down. Worked like a top.
Crap, I thought they were a bolt on guess I could fire up the mill,lol. So, an EFI intake works maybe I'll look into that then..
2.0 intake on a 2.3 requires a MAJOR adapter as the two intakes are different in every way. It can be done, but lot's of work, as the adapter will need to be about 1/2" thick and as big or bigger than the intake gasket off the 2.3. Go EFI lower as its the best, and the 350 Holley will bolt right on the adapter plate. Junk yards are full of them on Mustangs and Rangers.
Well, guess I'll just put a 2.0 intake on and keep the stock carb and put a Mustang header on then, first thing will be to re work the crappy ignition curve.
The Offy 'Dual Port' and what the 390 4 bbl. fits on. Entire manifold is split into two sections, upper and lower. Front two barrels feed upper level and back two barrels feed bottom level. Ford fours like that since they are so sensitive to fuel dropout. Only half the manifold area being used in normal driving keeps mixture velocity up.
Silly to mod to get a 4 bbl on a two barrel manifold like the 2.0, no way will it work unless using two barrels only.
Quote from: dick1172762 on December 18, 2013, 08:18:26 PM
It would be really hard to put a 390 on a 2.0 intake as the 350 is bigger than the hole under the carb. After you install the Racer Walsh adapter, you have to blend the metal under the adapter plate to prevent a step under the carb. You also can use the ERG plate from a 2.3 intake in place of Walsh's adapter plate. No carb that you can put on a 2.0 or 2.3 will give you better mileage than the stock Holley / Weber as long as it is correctly set up. Putting on a EFI lower intake even with a stock carb will be a BIG improvement on a 2.3. The stock carb is plenty big for the street, just the 2.3 intake is JUNK spelled with a capital J. Then 2.0 intake in near perfect and there's not much you can do to one.
So, the thing to do would be to put a 2.0 intake on with the stock carb and a good header and a good ignition curve then.
