looking for parts
Date: 06/19/2020 02:32 pm
Date: 12/24/2016 04:13 pm
Date: 10/31/2018 12:04 pm
Intake manifolds
Date: 03/06/2021 03:04 pm
Date: 03/07/2017 07:03 pm
Date: 03/06/2017 01:24 am
Date: 10/27/2018 03:30 pm
Automatic transmission
Date: 02/13/2021 02:52 pm
1976 Squire wagon
Date: 09/12/2018 10:30 pm
  • Online today: 269
  • Guests: 183
  • Total: 183
gas line from tank to pump
Started by tonij1960, December 02, 2013, 09:57:06 PM
All metal with short hose on each end, as amc says unless it's damaged no need to replace it, but if you need to make a new one might look into "AGS Poly Armour" tubing(available at any parts store)you can buy it in bulk(cheap) and make up your own line, easiest stuff I've ever used to work with it bends by hand for minor tweaks to fit and very easy to flare, made all new break lines in my Nova and it was a piece a cake..
Metal.
Unless damaged or cracked generally you never need to change it, too easy to flush that out there..............I've never changed an entire fuel line on a car in 40+ years of working on them unless going to bigger say for race car.
You can patch small sections in rubber and i commonly end up with last 3 foot or so rubber (from fuel pump up) on these since different things make me cut line shorter and shorter for things. I NEVER use that small OEM screw-in-carb filter, it's just asking for constant trouble in today's world of ethanol laced fuel. I always use a much bigger inline filter maybe 6 inches out from carb.
Line is either 5/16 or 3/8, thinking the smaller. FYI, steel brake line can be used in place of the metal part and easy to get, bend, and patch pieces together, cheap as well. Run line in factory location and be sure to fasten it down SECURELY even if you need to make up a couple more clamps than original, say if you had to patch in a short rubber piece in the middle of the run.
ToniJ1960
 Is it mostly rubber hose or is a part of it metal line?
What size will I need?
