78 windshield trim
Date: 02/01/2020 08:46 am
Date: 02/18/2017 04:41 pm
SEARCHING HOPELESSLY
Date: 02/02/2017 07:21 am
front end parts
Date: 03/30/2018 12:48 pm
Date: 06/19/2018 03:58 pm
Date: 09/12/2018 12:33 pm
Pinto brake booster needed
Date: 05/08/2021 09:00 am
Date: 02/28/2018 09:37 am
Date: 10/01/2020 02:00 pm
  • Online today: 116
  • Guests: 110
  • Total: 110
What are you using for a front mount with a factory latch?
Started by turbo74pinto, October 06, 2013, 08:51:53 AM
tintmaster
C. Eugene Brown
turbo74pinto
Innercooler. I will run 2 10 inch fans like I did in my 74 set up as pullers. I don't like the idea of loosing the lower support of the latch like mike has his set up. I set it on the lift yesterday and it looks like I can run a narrow longer one kinda behind the bumper at an angle. Then maybe build a shroud to it.
Front mount... Inner Cooler of Fan?  If fan it seems easy enough.  On my '73 I made a mount for a generic "out of the shroud" fan.  If inner cooler I think it relates to where and how (and how big) the factory latch will work.
turbo74pinto
What is supporting the bottom of the latch and the center of the grill now?
Mike Modified
turbo74pinto
My 74 runs hood pins so I have a ton of room for a front mount. I just picked up a 78 wagon and want to keep the original hood release. My turbo motor will be mild and still running AC and power steering. What are some of you running?
