Date: 06/05/2018 09:13 pm
Date: 10/26/2020 03:24 pm
Date: 09/19/2019 04:43 pm
front end parts
Date: 03/30/2018 12:48 pm
Mallory Unilight dist 2.0
Date: 10/25/2019 03:44 pm
Date: 03/25/2019 09:02 pm
Date: 06/25/2021 12:59 am
Date: 03/06/2019 06:40 pm
Date: 06/07/2018 01:45 am
  • Online today: 323
  • Guests: 286
  • Total: 286
Air shocks on these 1970 Ford Mavericks
Started by dianne, September 26, 2013, 09:20:00 AM
Running them up high just beats parts to death.
As an aside, we used to run two individual lines, one to each shock when racing AMC early, you could preload one side different from the other to make a single track rear then pretty much spin both tires like a positrac.
Jerry merrill
I put air shocks on my 72 Maverick and ran fairly high air pressure because no one makes good shocks for the rear of these cars. The car developed stress cracks in the sheet metal the mounting bracket is attached to, would not recommend them for mavericks.
Quote from: sedandelivery on September 30, 2013, 03:11:54 PM
My neighbor had a 1958 Lincoln 4 door the exact same color orange with an interior to match! I thought it was cool!
Sweet!
sedandelivery
Thanks, didn't care much for it at first but now it's kinda cool, lol. I've had a lot of Fords before and none ever had a sag, maybe I am lucky.
Quote from: 74 PintoWagon on September 30, 2013, 08:46:47 AM
Hmmm, mine don't sag???..
I LOVE the orange on that car!! I painted my 1977 Vega orange like that before I sold it off, it was red before. You're pretty lucky to have no sag!
Quote from: jeremysdad on September 30, 2013, 08:06:36 AM
I must be lucky, then. Mine was an old lady driven specimen of a wagon, maybe being a grocery getter allowed it to maintain it's rear ride height? Mine still has a slight rake to it, raised a little with new stock replacement shocks earlier this year.
You are lucky, I don't think I've seen a Ford with leaf springs that have ever maintained any height. You always see these cars with extenders on them to raise the back to normal height - looks like crapola to me!
jeremysdad
Quote from: joebob on September 28, 2013, 08:37:24 AM
I know next to nothing about engineering. That said, I have always wondered why the pinto sits with the back lower than the front. Is there a good reason?
Quote from: HOSS429 on September 28, 2013, 04:33:20 PM
no .. it`s a HOSS429 ... ha .. just a fastback i did my way .....i dont know why some of my pictures are big and some are small ...
LOL Nice though :-) That's my next one so I can relive my youth! LOL
HOSS429
Quote from: dianne on September 27, 2013, 06:45:04 AM
LOL ;-)
Is that a Boss? Nice! Had one back in the 70s - I'm old...
Just like all Fords with leaf springs, they sag...
JoeBob
77 yellow Bobcat hatchback
Deuteronomy 7:9
Thanks AMC! The shocks I have are air shocks for a Pinto hatchback. This just needs a spacer to fit in the wagon. What I was staying was that they don't make them for the Pinto anymore, but they do make them for the Maverick. The car may need as much as 2". What I don't want to do is get the spring extenders you see around, looks like crapola honestly. So we'll see I imagine. They sell an extra spring from what someone else told me that will raise the car back to level, air shocks just seemed like a simple fix to the problem.
I'm going to have the shocks installed and I think they may be OK.
You missed what I said, but in defense of you I didn't say it real clear. What I meant by 'all the way up' was them aired up as high as they go. Airshocks put more and more load on other parts like the brackets or mounts depending on how high in pressure you run them. I saw people with broken mount parts that ran the shocks aired up all the way.
If only aired up the 1 1/2" you may well be all right. The 'undriveable' issue comes when you have them jacked high and then lowering them allows big tires to rub bad or similar. If just to look different and not raised high then no trouble at all possibly. Now, depending on what breaks, you wouldn't want to drive if a hanging piece of something can now get caught to damage further.
Bayonet, flat plate mount, no difference, part is strong enough to take load or it breaks.
Springs carry the car weight not shocks, until you use airshocks, they then load parts harder than designed for, no matter, often the parts still last using them. If worried you could always pull mounts and take to weld shop to have them beefed up, the weld is what usually gives way.
I note mention of words Maverick and no shocks made for Pinto, if you have bought shocks that simply have what appears to have the correct fittings on both ends, that could be a huge mistake. You need a properly designed shock for the car it's going on, meaning correct stroke and body length to prevent possibly hitting inside because the working length is not right for what you are using them for. Big problem since not as many airshock apps out there as used to be, people look and say 'this will work' and totally wrong there. Top or bottom out shock and can damage it first time you do it. In freaky situation could even cause a wreck.
Quote from: HOSS429 on September 27, 2013, 06:38:22 AMi put a block of wood between the rear housing and the body .... hA !!!!
I remember doing that back in the day, scary for sure, LOL..
it still works as a shock .. it wont break anything.. now the way i jacked up my cars before i could afford air shocks was scary .. i put a block of wood between the rear housing and the body .... hA !!!!
LOL ;-)
HOSS429
Thank you.
I was told this by one of the guys I work with whose dad was a mechanic back in the 70s. I don't know, again I had my Mustang so jacked up in the 70s and nothing happened. This car wouldn't be raised much honestly, but I don't want to render the car useless to be honest if it breaks a shock tower or something and be stuck dead on the road.
Just don't know, he worried me...
Thanks for the comment on the Pinto :)
I used air shocks in my 71 runabout to level the car when towing a trailer.  I did not experience any structural problems with either the mounts or shocks.  I am not sure if there is a difference between car and wagon shocks.  If your load does not vary, a alternative may be to replace the springs (assuming they are still available).  Nice looking project.
Not breaking the shocks, he said it would break the actual car bayonet where it holds the shocks. I picked up NOS AC Delco shocks. Doesn't seem they make air shocks for the Pinto.
Question is still open, will it damage the car? Mainly the shock tower, or bayonet!
You need at least some (25 psi?) to not damage them. I think the ones that broke were run all the way up. I ran them for years on cars and never blew a one.....................we preferred Gabriel since the bladder was hidden, the Monroe? had the bladder exposed to rupture from rocks hitting it.
Someone at work just told me about putting air shocks on the 1970 Maverick and the 1973 Pinto. He said that these are bayonet mounts and that they stress the mounts and then break and render the cars undriveable. I used to have air shocks in my 1970 Boss 302, but that was back in the 1970s.
So what's the story, is it true? On the Pinto I would be raising it 1 1/2 inches and about the same on the Maverick.
Thanks ya all...
