Pinto Wagon
Date: 05/25/2018 01:50 pm
72 Pinto parts
Date: 12/04/2018 09:56 pm
Need seals Pinto Wagon
Date: 02/16/2017 05:09 pm
Date: 10/01/2020 02:00 pm
Date: 11/11/2019 03:38 pm
Date: 08/30/2018 12:59 am
1976-1980 A/C condensor
Date: 09/21/2020 10:43 pm
1977 Pinto for parts
Date: 10/10/2018 06:25 pm
Date: 03/13/2021 12:57 pm
  • Online today: 583
  • Guests: 498
  • Total: 498
Gaskets?
Started by dianne, September 21, 2013, 02:35:33 PM
You're making me dig in the cobwebs, thinking about it, I do remember that vertical pattern pump mount............man it's dark in that hard drive.
I just replaced the fuel pump on my 2.3 and it does take a SBC gasket.
jeremysdad
Quote from: amc49 on September 22, 2013, 03:33:00 AM
Thinking the very common smallblock chevy fuel pump gasket works fine there, the two bolt one not the four.
Early 2.0 uses an odd pump, with a vertical bolt pattern. Not sure for the 2.3 as I don't have one, but the part listed on O'Reilly's website does look like a standard SBC pump, so it very well might work in that application. If you have a 2.3, parts availability shouldn't be a big issue, since they were used in tons of vehicles.
Site says the 2.8 uses the same FP gasket as the 71-72 2.0's. YMMV.  What motor are you running?
I've had good luck with sourcing parts from RockAuto.com, if it's not something of immediate need (shipping time).
I have some extra distributor o-rings in the parts I have for you, as well as the original fomoco fuel pump which was good when pulled but I felt better with a new one. I kept it around as a good spare. No gasket for it though. They can easily be cut out of a sheet of gasket paper though!
Fel-Pro has all the gaskets you need, may have to order them though as a lot of parts places don't stock 2.0/2.3 stuff.
dianne
Does anyone know where I might be able to order gaskets for a Pinto? Harder than heck to find them...
I need the o-ring and gasket for a distributor and also the fuel pump gasket.
Thanks,
Dianne
Vehicles:
- 1976 Mustang II mini-stock
- 1978 Mustang King Cobra II
- 1979 Ford Pinto Runabout
- 1986 Chevy K5 Blazer
- 1997 Suzuki Marauder
