1972 Pinto SCCA BS race car
Date: 10/23/2018 04:01 pm
Date: 07/21/2017 11:49 am
Date: 01/23/2017 07:41 am
1977 pinto rear bumper
Date: 04/19/2021 11:57 am
78 pinto wagon
Date: 06/04/2020 12:42 pm
Date: 03/13/2021 12:57 pm
Date: 06/05/2018 09:13 pm
1979 PINTO PARTS--FREE
Date: 09/13/2022 02:05 pm
  • Online today: 134
  • Guests: 109
  • Total: 109
driver door window stuck
Started by renton481, June 13, 2005, 11:43:40 PM
renton481
Thanks Crazyhorse, I appreciate the info.  I'll give it a try.
The window crank, & door handle are indeed held by simpe phillips screws. The arm rest is held by 3/8 bolts in the bottom & a phillips screw under at the top. once these are off you can use a putty knife or a "panel popper" tool to CAREFULLY pry the clips out of the door, removing the inner panel. From there diagnosis of the stuck window regulator should be easy!
renton481
The window on my 79's driver's side door won't budge.  I guess I need to take the panel off and take a look at the mechanism.... but I don't know how to take it off without possibly wrecking the panel.  Could some one tell me how you take the panel off?  I know how to take the handles off -- it looks like they're just held on by phillips screws.  But how do you take the panel off?
