Mustang II C4 Transmission
Date: 07/28/2017 06:26 am
2.3 front sump oil pan
Date: 07/24/2018 03:17 pm
Date: 10/11/2019 11:13 am
Date: 05/22/2018 02:27 pm
Date: 02/18/2017 05:55 pm
74 hood
Date: 07/03/2017 03:46 pm
Date: 01/28/2021 03:49 pm
Date: 04/14/2023 06:15 am
Date: 04/27/2018 10:28 pm
  • Online today: 131
  • Guests: 69
  • Total: 69
leaking at the wipers (not)
Started by rare cars, June 13, 2005, 09:43:21 PM
BlueGoldPinto
Yes, I'll have to look for that stuff once I get over my fear of mice AND their smell and get my car started up again....
renton481
You could try enzyme cleaner that is used to remove smells of dog, cat urine, etc. from carpets.  It may take several treatments.
BlueGoldPinto
rare cars
My rare cars: '72 Pinto wagon (Pagon), 260" V-8, C4 Auto., Ice blue metallic. Plus seven other works in progress = I have a car problem!
BlueGoldPinto
Ahhh... Mr. Mouse and family and wet carpet.... I know the story, and the smell. The aroma has that certain GOOD GOD WHAT DIED IN HERE mixed with wet dog and cat, and closed up in the hot sun for quite a while sweet smell to it. ::) Yes, can't forget that.....
Don't worry though, you can pull that carpet and scrub it, wet vac it, let it dry, and use about 2 spray bottles of fabreeze on it, I'm gonna have to do that sometime too. And just for your info, you think I think that you think that your smart not, but I think that you think that smart I am, But I think not!!! SO THERE! ;D
rare cars
Both sides brother! The carpet was a gonner as it reaked of  Mr. mouse & family as soon as it got wet so I'll have to investigate further as I have come to realize(a big "DUH" for me) that the wiper posts just drain into the cowl (unlike past cars I've owned) oh by the way, I'm not as think as you smart I am! HA!
BlueGoldPinto
on both sides of the dash? Or just the passenger side? Both sides would make me suspect that your drain holes are plugged with rust. Unfortunatly like everyone else told me in my other post you read the only way to check that is to pull your fenders. If it's just the passenger side then that would make me suspect the lovely heater core. Put a bucket or a paint tray underneath the leak and check for green coolent. Or, you also could have a leaking gasket that could be the source of your troubles. either way, get something under that leak to prevent water from getting on that beautiful floor, and if the carpets wet, prop that up with a stick or screw driver or something and be sure to let it dry out!!!  ;) :) Hope that helps some, I know your frustration!
rare cars
I can see water leaking (floorwells full on both sides after all the rain) down from somewhere up under the dash. Can it be the wiper attachment points?  Luckily my car is a rust free colorado native & there is nothing clogging my cowl. I pulled the carpet and the floor pans are nice too but they won't be. Does somebody make new seals? HA HA
