Date: 07/17/2018 09:22 pm
79 pinto steering column
Date: 08/18/2018 02:00 pm
Date: 08/20/2017 01:34 pm
Date: 10/05/2017 02:26 pm
Date: 11/11/2019 04:49 pm
pinto for sale
Date: 09/11/2016 09:47 pm
Date: 07/08/2017 08:25 pm
Date: 03/30/2021 12:29 pm
Front grill for '72
Date: 03/02/2022 12:09 pm
  • Online today: 125
  • Guests: 76
  • Total: 76
EFI Fuel Pumps
Started by From_Jonah, August 20, 2013, 11:18:46 PM
Anyone know where there is a posting on how to hook up the wiring when you add an EFI from a Mustang 2300 to a Pinto? Thanks.
waldo786
I picked up one of the Holley Terminator EFI kits, and am going to use bo-port ported heads, offenhauser dual plane 4 bbl intake, and possibly headers.  The EFI kit comes with an external fuel pump.  They do recommend you place it close to the gas tank as someone else mentioned they do like to push rather than pull, so keep it close to the tank.  Also makes it easier to replace if you ever need to do that.  Good luck - I'm hoping to have mine up and running sometime next spring or summer.  Keep us updated on your  progress.  My system has a return line, and I found through the forum a fuel sending unit that will supposedly work with our cars from a Mustang II that has a return line in it.  http://ecat.spectrapremium.com/prod/ALL/fg178b
I am going to get one of these for return line.
You can do it! I did it! Its really pretty easy. I had maybe 9 connections to make, including wiring the internally regulated alternator in place of the stock externally regulated one....
From_Jonah
I hope so. At least this website exists to help! Haha.
It's really not hard, you can do it..
From_Jonah
It is! I've put it off too long but I have a phobia of EFI so I'm just having to try and convince myself that I can do this.
Well, it's about time... :D
From_Jonah
Sorry for the late reply everyone, but it looks like this is about to become reality! I blew the head gasket in the carbed 2.3 so I have an excuse now.  ;)
Quote from: pintoguy76 on September 01, 2013, 06:42:10 PMBTW Jonah, based on your avatar photo it looks like we have the same car. An orange 74 station wagon.
That makes 3 of us, lol...
I too used a ford pickup fuel pump in my pinto EFI swap. Works great. I put a low pressure pump right before the ford pickup high pressure pump and used wire ties to tie the two pumps together, then mounted it in front of the gas tank on the body.
I did exactly what wittsend did. Cut the electrical and fuel line connectors off the truck and used them on the car. Along with the fuel filter and its bracket...alth ough that isnt pictured.
Better to put pump in tank, but if pumps you got have the pressure you need you can really put them anywhere.
Better in tank because ALL pumps like pushing better than pulling and the pump behind the pressure head stops all vapor lock. Easy to fuel-cool the pump in tank too. Easier to get going too if you run out of gas. Many modern electric fuel pumps will burn up if they are not primed instantly, or why all car  owners manuals now say to never run out of gas. As little as 60 seconds running dry can tear them up.
From_Jonah
Okay awesome. I'm still trying to decide for sure what i wanna do.
My "External" fuel pump came off of a Ford pick-up.   $11 at Pick A Part.
fast64ranchero
I have two EFI Pinto's neither have a "in tank" pump, both ext. frame mounted and I have not had any problems.
72 old V-8 parts Pinto
73 pinto, the nice one...
pintoman
I use a external pump from a xr4ti.it has been on the car for the last 9years without any problems.
you do have to have one in the tank and you don't need 2 on the frame. You will just need one good inline high pressure pump I have a bosch 044 its even better then a walboro 255 inline.
From_Jonah
So, I'm sure this has been covered before but I can't seem to find an exact answer on what I'm looking for. Is it absolutely mandatory that I have an  in+tank pump if I were to convert to EFI or can I run two on the frame?
