Pinto for sale
Date: 04/19/2017 10:15 am
pinto floor mats??
Date: 01/11/2017 07:27 am
79 pinto small parts
Date: 04/24/2019 03:16 pm
Date: 12/31/2017 09:03 pm
75 wagon need parts
Date: 05/28/2020 05:19 pm
79-80 full glass hatch
Date: 01/04/2017 04:04 am
Many Parts Listed Below
Date: 04/20/2018 11:15 am
Pinto wagon Parts
Date: 06/23/2021 03:25 pm
Date: 08/22/2017 09:21 pm
  • Online today: 178
  • Guests: 141
  • Total: 141
Pinto won't start
Started by redwinggirl, August 12, 2013, 03:36:19 PM
pintoguy76
I agree. Ignition switch or neutral start switch.  However some ignition switches are rare and hard to find. I think the one on for my 74 is not listed at any parts store... can get them on ebay tho, but they arent very cheap.
Rocket science...................LOL.
HOSS429
Quote from: 71pintoracer on November 12, 2013, 06:00:20 PM
, you need a new mechanic.
i was kinda thinking that as well .. it can only be a few things .. ignition switch ( at the bottom of the steering column ) .. or neutral safety switch .. if it starts with a  toggle switch  the solenoid must be good ..but if you can live with it go for it ...
Geeeezzzzz.......it's a freakin' Pinto for crying out loud! If your "mechanic" (I use that term loosely) can't diag a simple issue like this, you need a new mechanic. It starts with a remote start switch hooked to the solenoid, correct? That eliminates everything except getting 12v to the S terminal from.....the ignition switch! Put your voltmeter on the S terminal (with the wire still attached) turn to start and see what the reading is. Pretty sure Tonij1960 already asked this so..... :)
redwinggirl
so, after all this I finally took it to a mechanic to figure it out. At least I'm not stupid cause he couldn't track the electronic gremlin down, either. Putting a push button start in it.
pintoguy76
Was this issue ever solved?
Quote from: HOSS429 on September 14, 2013, 03:28:46 PMthe most simple of things can stump the unfamiliar ....(
Man, ain't that the truth..
HOSS429
Quote from: amc49 on September 14, 2013, 03:04:14 PM
Yes, way too much fish flopping around here, the trouble should've been found in five minutes..................
very well would be if any of us were on the scene but that cant happen in the interweb world ..the most simple of things can stump the unfamiliar ....(
jeremysdad
Quote from: amc49 on September 14, 2013, 03:04:14 PM.....not like a PCM car with elevendyfortytwo other things to check.
Sounds you've fought with a GM OBD 1.5, as well. lol
Yes, way too much fish flopping around here, the trouble should've been found in five minutes..................not  like a PCM car with elevendyfortytwo other things to check.
Once a solenoid has vaporized some of its' internal contact point, it can occasionally not work at one application then go back to working fine. Pull it apart and find the contacts all eroded and pitted to make semi-contact.
jeremysdad
Quote from: tonij1960 on September 14, 2013, 02:12:03 PM
Theres really no advantage of a test light over a dvom if you can use it at all correctly. I worked on cb radios tvs vcrs 15-watt per channel high end audio equipment, have some engineering studies and hobby experience fabricating pc boards designing and building analog and digital circuits.
A Pinto electrical system is a piece of cake for me. Get those three or four readings I mentioned and go from there. A circuit is a circle so we have to follow it around thats all no jumping ll over the place. Lets get this Pinto going already.
Agreed. Jumper wires from 'I' on the solenoid to '+' on the coil, then one from the hot post to 'S' on the solenoid. It should start. If not, battery connections. If so, bad solenoid.
I didn't re-read this entire novel, is it actually cranking and not starting, or is it a no crank scenario? :) lol
ToniJ1960
 Theres really no advantage of a test light over a dvom if you can use it at all correctly. I worked on cb radios tvs vcrs 150-watt per channel high end audio equipment, have some engineering studies and hobby experience fabricating pc boards designing and building analog and digital circuits.
rramjet
Sure sounds to me like ignition switch related although interestingly my 73 wouldn't start the other day after getting gas and I think the problem was at the start relay. Tapped it and wiggled the + lead on it and everything was fine. No problems since. Started many times with no problems in the 3 months I've owned it. I am a little suspicious of the + connection because I was taking it off to use a remote starter switch to bump the motor when checking timing belt alignment.
I was also going to suggest troubleshooting using a test light can sometimes be easier than a voltmeter.
Make sure you get one for 12 Volt circuits.
The bulb should be incandescent, (has a filament), which has the added advantage over a Voltmeter of verifying circuit contacts are conducting current. It is possible to measure voltage in a circuit but have no or too little current particularly where switch or relay contacts are involved although this is more common in low power circuits.
redwinggirl
Good point about the battery. Since there's no corrosion anywhere. Ill have autozone chk it out.
Usually if you have to tap on something to work odds are it's a bad ground.
ToniJ1960
 connect your voltmeter leads directly at the battery posts and have someone turn the key. If the voltage drops the battery is weak if not the battery is ok. Then put the black wire on a ground and the red on each terminal at the relay, read those voltages when the key is turned. Use a clean spot on the engine or the body for a ground not the battery. Tell us what you get and we go from there.
krazi
I had a similar problem today at work. try tapping on the solenoid with a lighter or something of similar size.
yeah, I'm Krazi!
Check all connections and make sure there's no corrosion anywhere.
I'm with tonij, battery not a known quantity there yet. I've fixed so many cars I can't count that owner swore up and down battery was good. Clicking at solenoid says the igntion start circuit is working. Just not enough battery to start car. Remote switch means nothing, bad battery will not crank five times then suddenly work once, battery still bad there.
The battery is bad to me until someone has passed a load test at proper CCA, a lesser CCA battery can be BRAND NEW and not crank the car. Simply checking static volts on a battery really is quite worthless.
redwinggirl
finally got a voltmeter! Battery is spanking clean, has new cables, too. According to the books, there is no NSS switch on the manual trans.  There are 3 wires that come off the solenoid. 2 are red, 1 is white/ blue stripe. The wht and 1 red go through firewall into connectors and then on to ig. switch. The other red goes to the ig. module. None of these seem compromised.
ToniJ1960
 But if the relay clicks when she turns the key it doesnt seem like a remote switch would make any difference. I still think its the battery or the connections are dirty. A post hole cleaner and a $4 voltmeter will most likely be all she needs.
nnn0wqk
I took that that she used a remote switch at the starter solenoid. If it started at that point pretty well rules out bad battery connections etc. I do not remember a Pinto using a clutch neutral switch so that would tend to point to the switch at the base of the steering coluum. I agree that a voltmeter would be a great investment at this point, should save a lot of parts replacements.
ToniJ1960
 Im not sure what you mean by a `remote start` did you use a jump starter or a remote switch?
Get a $4 voltmeter from harbor freight or wherever and we can walk you through tracing out the voltages to see exactly where it could be getting lost at.
krazi
hold the key in the start position with your left hand, then move the shifter with your right hand. it might start, it might not. had this problem with a dodge I had.
yeah, I'm Krazi!
redwinggirl
Finally had some time to test these things out. It WILL start and run using a "remote start". I replaced thr ignition module thinking it was a link in the chain. Nothing. Batteries good, replaced the elbow on the solenoid. Traced the wiring back and there are no bad wires. I just don't get it. Help.
Battery terminal condition or battery bad the most likely issue, how old is battery? Some of the answers given here amaze me. Yank battery and charge it up and load test at the parts store, that'll tell the tale.
Clicking at the solenoid says not enough power to pull solenoid all the way in, or why it clicks.
krazi
did you remember to put a nickel in it first?
p-put
i-in
n-nickel
t-to
o-operate
yeah, I'm Krazi!
jeremysdad
Quote from: HOSS429 on August 20, 2013, 03:23:12 PM
good question .. since you say it`s a stick you can have someone give you a shove with the switch on  and pop the clutch in 2nd gear and see will it run ..then alway spark on a hill ..... HA !!!
Like.
Yeah, that always works. Even with a dead battery! Too many autos have ruined my mechanical brain. lol
Many a morning I spent with a dead starter, a 64 Falcon, and 5 people pushing on a flat road. :D lol 'Hey, you want a ride to school? Cool. Told you this was a bad place to go---no hill.' Now, mush, puppies!!! lol
Def 2nd gear, though...1st will throw you through the windshield. Don't ask me how I learned that.
HOSS429
Quote from: jeremysdad on August 20, 2013, 03:11:30 PM
When was the last time this car started? It's a Ford, they're pretty straightforward (all I've owned since I got my first car in 93). lol
good question .. since you say it`s a stick you can have someone give you a shove with the switch on  and pop the clutch in 2nd gear and see will it run ..then always park on a hill ..... HA !!!
