WTB Cruising Wagon
Date: 12/07/2016 05:35 pm
Racing seats
Date: 10/24/2019 09:41 pm
Date: 02/21/2017 06:29 am
Date: 07/01/2019 12:23 pm
Need 2.3 timing cover
Date: 08/10/2018 11:41 am
Date: 02/18/2017 04:41 pm
72 Pinto
Date: 03/07/2019 12:07 pm
Date: 08/22/2017 09:21 pm
Date: 08/22/2018 09:23 am
  • Online today: 178
  • Guests: 162
  • Total: 162
Pinto won't start
Started by redwinggirl, August 12, 2013, 03:36:19 PM
jeremysdad
In the following order: Battery connections clean/tight, connections at solenoid clean/tight, connections to ground clean/tight, connection from solenoid to starter clean/tight? If in doubt, disconnect everything in order, and hit it with some emery cloth or sandpaper, then reassemble and tighten properly. It's something simple, usually.
When was the last time this car started? It's a Ford, they're pretty straightforward (all I've owned since I got my first car in 93). lol
ToniJ1960
 They can be because of the connectors not being clean or tight, and they can be from where the connector goes on  the cable too. I had both of those over the years. Of course it can be bad connections at the other end too. Its like a chain or  a big circle ( the word circuit comes from circle).
Just keep following it from one end to the other, with the test light or cheap voltmeter. A post hole cleaner is another good thing to grab for $2 or $3
jeremysdad
I've gotten a few faulty solenoids from part stores before. Maybe try an exchange if everything else is a dead end. :) 9/10 though, my 'clicks' have usually been battery connection related, either at the battery or at the solenoid.
ToniJ1960
 Even a $4 voltmeter you can find at harbor freight is a good thing to have. I got one just to keep in my car. Read the voltage right at the battery clamps without touching the posts while someone turns the key. If the voltage stays close to 12 the battery connectors arent the issue. Then check from the positive connector to a ground and do the same. If its still reading close to 12 a little more even, the ground cable is good. Then read from a ground to the other end of the cable from the positive of the battery and have someone turn the key again. If you get 12v then the positive cable is ok.
Then check from ground to the other side of the relay, and have someone turn the key. Close to 12v again thats all ok. Then from ground to the solenoid wire on the starter. Turn the key read the voltage, same for every test.
You could use the test light the same way. If the wires are long enough.
Is the clicking coming from the relay mounted on the firewall not far from the battery where the positive cable goes to? It sounds like a weal battery or bad connections if so. Follow the tests youll find the culprit. If you get a lot of voltage drop at the battery connectors when someone turns the ky, read right on the battery posts and have them turn the key. If the voltage drops at the posts too, t he battery is weak. If the voltage stays at 12 the connectors arent clean or arent tight.
Scott Hamilton
I'm going with Jonah's suggestion but at the Battery- take off the negative cable from the battery, clean and reinstall. I had a pinto once that did this and I grabbed the negative battery terminal and pushed and turned so the car would start- it became a regular thing.. After I cleaned it- it was fine.
This is fun... let's see which one will fix this issue... All are great suggestions,
redwinggirl
Have I mentioned how much I hate electronics? So not spark at the screw on the starter solenoid, holding the key in the start position produces clicking at the coil, but no start. Don't own a volt  meter. Just a circuit tester. Advice?
redwinggirl
Good advise. She's a manny; won't ever drive an automatic. Unless it's free.
OhSix9
the odds on it actually being the switch are slim to almost none. in park jumper from where the battery connects to the solenoid to the terminal that normally holds the red/ blue wire. use a well insulated screwdriver.   does the car crank. crank yes grounds and solenoid are good. crank no change the solenoid. crank yes move the ingniotion switch to run and jumper again . will the engine run?   back to testing.   get a test light and connect it to the red/blue wire and then clip it to ground. does the bulb light when you put the key in the start position?  light yes power is reaching the solenoid in crank. again possibly solenoid or a poor ground to it. .  light no.  check the neutral start switch for continuity in park and neutral if its fine start tracing the red/blue wire looking for a fault. after all that look at the box on the bottom of the column.
Virgil to Sid
From_Jonah
I had this same problem a couple of weeks ago and it was a bad ground at the starter solenoid.
redwinggirl
Based on these replies I studied the wiring diagrams and I believe it is the ignition switch. The brake light icon goes on when I try to start without reason and per the diagrams that is related to the ig switch. Will replace wiring from there to solenoid as well.
I'm thinking neutral switch maybe out of adjustment, try moving the shifter while cranking and see what happens..
redwinggirl
Thanks for the ideas! I'll get back to you.
D.R.Ball
So do you have the rubber elbow the goes to the S terminal on the solenoid ?  It should have two wires. If so the connector on the inside might be worn out. I usually cut the elbow off , soldier on a ring terminal to each wire and bolt them in place.
HOSS429
if it is an automatic set the brake and try to start it in neutral ...neutral safety switch ?
289Wagon
 If you have someone available, have them hold the ign. key in the 'start' position and check for 12V power at the 'S' terminal on the starter relay'
289Wagon
 There could be several reasons. I would start by checking the ignition switch mounted on the lower part of the steering column.
redwinggirl
My 1978 Pinto quit starting. It has a new voltage regulator, starter solenoid and as of today a new starter. When I turn the key lights come on, radio works but no grinding at all. Ideas?
