Date: 01/23/2023 02:22 pm
Squire trim
Date: 03/28/2018 10:11 am
Date: 02/05/2017 09:45 am
Automatic Wagon
Date: 06/14/2019 11:22 pm
72 Pinto parts
Date: 12/04/2018 09:56 pm
Date: 01/18/2017 05:35 pm
Date: 01/10/2022 03:41 pm
1978 Pinto Wagon V8
Date: 04/28/2023 03:26 pm
1979 Pinto Rear Bumper
Date: 03/26/2021 03:26 pm
  • Online today: 1,972
  • Guests: 120
  • Total: 120
Before I bolt this in. T-5 question
Started by amxtra, August 10, 2013, 09:56:28 AM
amxtra
  I did find a long throwout bearing, but no specs or description about it, is there a link, was I in the right spot, or as usual am I completely lost?
It seems like that could fix the problem, right now its just all free play no engagement.
Jerry merrill
There are several thicknesses of throw-out bearings available according to Racer Walsh for different applications and mix matching bell housings and flywheels.
Or maybe the throwout bearing for the MII?? I haven't installed mine yet but I have a new flywheel/PP & disc for a Turbo Coupe so I sure hope it works.
amxtra
  The turbocoupe came with a new disk and pressure plate prev owner had bought it just before the accident. Installed it and the fork wont reach the pressure plate. Im guessing I need the pressure plate off a T5 cable clutch car? Anything specific ?
Thanks
Yeah, the oil pan & mounts should be identical to Pintos.
amxtra
nice write up. Mine is indeed the D5, so that should work. The motor mounts and oil pan should be the same to I would imagine
If it's a D5 bellhousing out of a MII then it works with the T-5.
I wrote this up awhile back & it has all the part numbers.
http://www.fordpinto.com/pinto-faq/comparison-between-d5-d9-direct-pull-bellhousings/
amxtra
  Have found lots of information on the T5 swap, and lots on the bellhousing but not specifically an answer to this question.
I have the oil pan, motor mounts and bell housing from a 4 speed mustang II, Should these pieces all work in my 77 Pinto ?
Im guessing with the II housing I shouldn't have any clutch cable issues like with the fox body housing and the bellcrank ?
Anyone know for sure?
Thanks
