Date: 03/15/2023 02:16 pm
72 PINTO WAGON
Date: 09/23/2018 06:16 pm
Date: 02/25/2017 08:45 pm
windshield
Date: 04/14/2018 08:53 pm
Date: 03/14/2020 01:52 pm
Date: 06/24/2020 06:12 am
Date: 04/07/2021 06:12 pm
Need 2.3 timing cover
Date: 08/10/2018 11:41 am
1971-74 Various Pinto Parts
Date: 01/18/2020 03:44 pm
  • Total Topics: 16,268
  • Online today: 673
  • Guests: 420
  • Total: 420
Brakes - re build or new ?
Started by Reeves1, July 21, 2013, 05:41:01 PM
OhSix9
Ok dokie.
since you are replacing the master are you upsizing the brakes right?  5 bolt I assume with granada rotors and the gm calipers at minimum and possibly the kit to bolt cobra brakes on the mII spindles and something to match the healthy v8's out back as well.  this little doodad is a combination balance switch (to throw the brake light when one side looses pressure) and a proportioning valve / distribution block  You can step up to a late 70's early 80's f250 master for the big bore 15/16ths or 1 inch vs 7/8ths i think and still bolt to the stock holes and put a prop valve after this or if as you say it is full of junk and you have to tinker with it anyways , chuck it all and get an aftermarket one like this
http://www.ebay.ca/itm/Black-Adjustable-Proportioning-Valve-And-Distribution-Block-/161005676342?pt=Motors_Car_Truck_Parts_Accessories&hash=item257cafa736&vxp=mtr     kills three birds with one swipe of a credit card.
Virgil to Sid
No one worked on one before ?
Next time I have the time, I'll take it apart to see what makes it tick....
Water/rust/gunk etc was in the master. Got a new master & replacing the whole system.
Can you buy this new ?
