Date: 07/17/2018 09:49 pm
1971 Pinto 5.0L
Date: 12/02/2017 12:23 am
95 2.3l short block
Date: 03/18/2017 04:54 pm
Date: 10/01/2020 02:00 pm
Date: 09/09/2018 03:22 pm
v8 springs
Date: 05/07/2017 04:46 pm
Wanted hood hinges
Date: 02/17/2020 05:30 pm
Mustang II C4 Transmission
Date: 07/28/2017 06:26 am
Front sway bar frame brackets
Date: 07/13/2017 01:05 am
  • Online today: 2,567
  • Guests: 427
  • Total: 427
Can Gauge Clusters Interchange?
Started by James Meter, July 01, 2013, 10:07:49 PM
Bill (77turbopinto) documented it somewhere.  I looked a little tonight but did not find it.  It might be buried in his tan Pinto thread.
James Meter
Damn.. any chance you'd have a diagram of which ones went where? I just sold the old wagon (with most wires still attached))
Quote from: James Meter on July 05, 2013, 10:14:02 PM
What is this wiring harness of which you speak?  ???
The engine / underdash wiring harness.  I sold the harness out of an 80 bobcat I had along with the gauges to a local guy.  Two days later, he had the car running and driving without too much trouble.
However it is possible to get them working with the non-tach wiring harness.  I have never done it though.
James Meter
I thought there was a write up somewhere that showed what needed to be done to convert to the tach cluster without changing the wiring harness.  I would do a search.  I want to say 77turbopinto did it.  If you want to do it right, I would change the harness as you will need to run the wires for the tach feed and change the sensors from the idiot light ones to a gauge.
bbobcat75
not too sure but if you dont end up using the 3 gauges from the wagon i would be intrested in them for my 78 wagon, some one before i bought it took them out and installed custom cheap china ones!!
thanks and good luck!!
1975 mercury bobcat 2.8 auto
James Meter
Long story short, I bought a fairly complete (but rusted to all hell) '77 Pinto Stallion Wagon (4-speed stick) to 'donate' parts to my '74 Runabout (automatic).
My main concern (since I have most everything else lined out) is that the RPM gauge (uses a black plug w/4 prongs) may not be able to mount in my runabout (not worried about the dash, just plug-ins). I've never taken my dash apart in the Runabout and have no honest idea.
Also: In the wagon, there's 3 gauges in a cluster; Oil, Amperage, and Engine Temp. Since all three of these are located within my Speedo on the runabout...can I just re-route the wires to the middle-of-the-dash cluster?
Thanks dudes!
