74 pinto
Date: 09/11/2016 06:32 pm
73 Caliper Retaining Key
Date: 10/28/2021 07:49 am
Date: 06/19/2018 03:58 pm
2 Station Wagons for sale
Date: 04/20/2018 11:10 am
79 Wagon with many extras
Date: 07/08/2020 04:18 pm
73 rear hatchback glass
Date: 07/06/2017 11:33 am
2.8 Engine mount brackets
Date: 12/28/2016 11:42 am
Brake rotors
Date: 03/24/2017 09:02 pm
Date: 02/27/2017 10:10 pm
  • Online today: 376
  • Guests: 386
  • Total: 386
D9ZC-7515-BA clutch fork
Started by Reeves1, June 19, 2013, 07:54:08 AM
Most guys just cut a slot in a washer that has a small hole after cupping it with a ball peen hammer & weld it in
My fix for the blue one was to cut that small piece out of a Pinto fork & weld it in.
You have other ways to fix ?
I got another Pinto fork to cut up....
I knew it would work. Only difference is the hole is larger than the Pinto cable ball but it's an easy fix.
Quote from: Pinto5.0 on June 20, 2013, 10:32:04 PM
http://www.summitracing.com/parts/atp-za125/overview/
Same, except made in China.
Never mind the bubbles in the weld on the blue one (will be re-done). Also, that welder will be given back to the neighbor/owner. I bought a new one that works right.
Summit sells one for 20 bucks. That's where I got mine. Mine is buried in my storage but I did check the fit in my D9 bell a year ago & it was perfect.
http://www.fordpinto.com/pinto-faq/comparison-between-d5-d9-direct-pull-bellhousings/
You have one you can take measurements from ?
I'll do same with the one I have (need 2 total) tomorrow.
Have you tried a 5.0 fork in it? That fork fit my D9 bell perfectly
Been trying to find one. Got one ?
