pinto parts for sale
Date: 07/25/2018 04:51 pm
Date: 02/11/2020 12:09 am
Date: 07/08/2022 11:51 pm
13" Style Steel Trim Rings
Date: 10/09/2020 10:35 pm
Date: 04/13/2018 11:30 am
Date: 03/25/2019 09:02 pm
Date: 09/01/2017 11:58 am
Deluxe Steering Wheel
Date: 10/16/2017 08:13 am
Front Body parts needed
Date: 02/09/2018 06:09 pm
  • Online today: 882
  • Guests: 700
  • Total: 700
Brake rotors for a 72 wagon...
Started by jeremysdad, June 16, 2013, 05:25:33 PM
There is some work to make them fit. I think it involves turning some material off the back of the rotor on a brake lathe but I'm not sure if the exact details.
jeremysdad
So, finally finished a took-way-longer-than-anticipated front end rebuild on my 72 wagon. First, I would like to confirm that the 74-up lower ball joints will function perfectly on the 71-72 suspensions with some creative grinding with a Dremel on the 2 holes the strut rod studs go through (small sanding drums, took me about an hour per side). :)
Now, the reason for this post. Having a tight suspension (new rack and pinion, upper/lower balljoints, outer tie rod ends, upper/lower bushings, shocks at all corners, sway bar end links, strut rod bushings) has highlighted an issue I've put off for financial reasons since I redid the brake system last fall.
My rotors were so thin (have original D22 Ford part numbers lol) that O'Reilly didn't even charge me for turning them. At $100+ per side, I couldn't afford new rotors then, and can't really, now. But, the general tightness of the front end REALLY magnifies the vibration/wobble when the brakes are applied.
My question is this: Can anyone confirm whether 74+ rotors will bolt on and function with the early calipers/pads, etc? I've seen the specs for both side by side, and they look so close, it isn't really funny.
I would just buy them and try, but after being down for 2 weeks, I really need my car back, it's my DD... :/
