1980 Pinto taillights
Date: 12/26/2017 03:48 pm
McLeod Clutch
Date: 04/12/2017 12:08 pm
Date: 08/09/2018 11:09 am
Date: 12/31/2017 11:14 pm
2.8 radiator
Date: 10/25/2019 04:10 pm
Date: 10/25/2019 03:30 pm
Date: 08/26/2018 06:35 pm
Date: 01/30/2017 01:48 pm
Pinto Runabout wanted
Date: 06/05/2018 04:42 pm
  • Online today: 882
  • Guests: 697
  • Total: 697
Brake rotors for a 72 wagon...
Started by jeremysdad, June 16, 2013, 05:25:33 PM
I only found them on Amazon because you posted the Rock Auto part numbers. Without it I doubt I would have turned any up.
jeremysdad
A follow-up report.
As of right now, it looks like I'm butting heads with Rockauto, so I think we'll just be eating the 90 bucks. Lesson learned: always check Amazon. lol
Rotors came today at about 3, and by 4:30 they were installed. OMG it stops sooooo smoothly now!!! :) Now to the alignment shop one more time, and I'm calling this project done for this go around. :) Thanks again for all the input/help/suggestions, guys! :)
Edit to add: I created a thread in Parts Resources with the link to Amazon. (Gave credit to Pinto5.0 :D)
bbobcat75
BY LOOKING AT ALL MOUNTING AND TIE ROD END HOLES AND SO ON ALL LOOK TO BE FACTORY NO MODS AT ALL!! THAT IS WHY I WAS SO f%^&ING CONFUSED WHEN TRYING TO FIX THE BRAKES, LEFT FRONT PADS WHERE WASTED AND GROUNDED THE ROTOR TO NOTHING SO WAS JUST GOING TO DO A EASY ROTOR AND PAD SWAP AND TOOK 5 DAYS TO GET IT DONE, AND ENDED UP BUYING A SET OF USED ROTORS JUST TO SAVE A BUCK AND GET THE CAR BACK ON THE ROAD.
BUT ON A SIDE NOTE THE FRONT RIMS ARE A SET OF EARLY 71-73 MAGS AND IF I HAD THE 74-80 ROTORS THEY WOULDNT FIT SO IT WORKED OUT FOR ME IN THE END!! LOL
TAKE CARE AND GOOD LUCK WITH YOUR BRAKE D BACH ALL!!!
1975 mercury bobcat 2.8 auto
That would be a ton of work for no gain if that was done. The tie rod hole would have needed hogged out to work & the upper hole on the late caliper bracket would be off by 5/8" at least plus the lower hole would need a spacer.
jeremysdad
Quote from: Pinto5.0 on June 19, 2013, 06:46:08 PM
Yeah, those are late calipers & pads for sure. My guess is you either had the wrong bearings or maybe the new rotor had the race installed part way. All my rotors had races already.
The bearings should have been Set 12 & set 13 in Timken if I remember correctly.
Agreed. I have not seen that caliper set-up, in person, as I have an early model. I question: Have the mounting holes been 'hogged out' to fit the later brackets to the earlier spindles, or vice versa? What I have seen for making the 'All in one' swaps fit early models, it's mainly a mounting-location issue. ;) Been wrong before... lol
They are Set 12 and 13, same seal.
bbobcat75
last 4
bbobcat75
3 4
bbobcat75
pics 2 3 4 5
bbobcat75
rotor pic 1
Quote from: jeremysdad on June 19, 2013, 09:55:43 AM
I'm not even commenting on that...rofl Good find, I thought about checking Amazon, but didn't. Ah, well...Just a hundred bucks... :/ rofl
Edit: I have emailed the kind folks at Rockauto to see if they will be nice enough to adjust the price of the order for me. Will let ya'll know what they say, and yes...I feel like a tool for not having checked Amazon. lol
I Googled the part number & Amazon popped up. I hope they do something to adjust their price at Rock.
Amazon is where I found my ceramic coated Pacesetter header for 250 bucks. That's what everyone wanted for a painted version
bbobcat75
JEREMYSDAD  IF YOU PM ME YOUR E-MAIL ADDRESS I WILL SEND SOME PICS OF WHAT I HAVE ON MY CAR! TRIED TO POST ON HERE BUT PHOTOS TOO LARGE, GET THAT EVERY TIME I TRY TO POST A PIC!! GRRRRR
jeremysdad
Quote from: Pinto5.0 on June 18, 2013, 06:04:55 PM
http://www.amazon.com/Raybestos-6022R-Professional-Grade-Assembly/dp/B001C6QA1Y
Having the part number made it easier to find them.
bbobcat75
Polara
Will the later spindles bolt on to an older car? I think they are a bit taller and will lower the roll center. They
can be had for about $100 for the pair and the rotors are about $30
jeremysdad
The solid-gold rotors I ordered: http://www.rockauto.com/catalog/raframecatalog.php?carcode=1135112&parttype=1896
I would like to note that these apparently have a 3 year/36,000 mile warranty...having read through the fine print, I believe it would most likely be an 'I already bought these elsewhere and just need a refund' situation (which is why I really hate ordering parts online, but money and all that). But, 3 years and hopefully some money back...cool. I'll take it. :) I'm laying out my Rockauto invoice, overlaying my O'Reilly receipts for new pads and bearings, and saving the resulting picture. :) Saved $70 versus getting them through O'Reilly, and they're Raybestos (probably the exact same thing). Rockauto still has a listing for the Centric part at $10+ less, but add to cart, and they're unavailable. If you want to direct-replace your early rotors, I would advise to get these before they're gone. :)
Here's to smooth braking...having a well running car that accelerates at will is awesome, but stopping smoothly is everything. :)
jeremysdad
New rotors will be here tomorrow, according to Fed-ex. :)
bbobcat, you should pull a wheel and post a pic so we can see what you're working with. As 5.0 stated, you have something weird going on, one way or the other.
Thanks for the input guys! I'm going to run these til they die, and figure out/source parts in the meanwhile.
Quote from: bbobcat75 on June 18, 2013, 07:31:13 AM
THESE FRONT BRAKES CONFUSE THE HECK OUT OF ME, MY 78 HAS THE RIGTH CALIPERS BUT USES THE 71-73 ROTORS AND EVERYTHING LOOKS STOCK NO CUTS WELDS OR GRINDING, THE ONLY THING I CAN COME UP WITH IS THE SPINDALS WHERE CHANGED AT SOME POINT OF ITS LIFE, BUT WOULD THINK THE CAILPER MOUNTS WOULD BE DIFFERENT FROM A 73 - 74 ?!?!?
The only difference between the rotors appears to be that the late rotors have more meat on them. I'm guessing you had something else keeping you from getting the late rotors on. The late calipers wont bolt to early spindles. I assumed you had the early calipers too.
bbobcat75
Here's the Granada swap for future reference.
http://www.fordpinto.com/pinto-faq/front-disc-brakes-(4-5-lug)/
If you look at the after machining pic the rotor that's cut looks like it has as much meat left as the stock early rotor. I'd run them.
jeremysdad
That's kind of what I was imagining you'd have to do. I guess I'll run these solid gold rotors I just bought til they die, and work on figuring out the best way to go in the future for an affordable setup. :) Thanks for the info, maybe I didn't go far enough through the search results.
Side note: Running the newer rotors might make me nervous, having to start with new rotors cut down to their minimum thickness. Anyone else? :)
http://www.fordpinto.com/pinto-faq/how-to-install-5-lug-9'rotors-on-71-73-pinto/
After 2 days I found the info. I was right about machining the rotor on a brake lathe. It has to be cut to fit the early calipers. Get used 4 lug '74-up rotors out of the boneyard & give it a shot.
jeremysdad
The bearings are the same, 71-80. I figured that, being my daily driver, I'd be better off just ponying up and ordering the right stuff for now, so I did. And yeah, it was painful, but after a discount code I found for Rockauto, got both new application specific rotors for $246.42, shipped. (It really hurt to type that number...lol)
In my head, I can see what *should have to be done to make the newer style rotors work, but in the interest of my sanity...at the insistence of my wife, went this route. Ultimately, it boiled down to being unsure whether the caliper/pad combo would fit over the newer rotors. That being said...
There would be some interference between the rotor and the caliper bracket, I'm sure. Personally, I would probably grind the mounting bracket a little, paint it, and call it a day. Yeah, probably lots of grind a little, test fit, remove, etc.
As I said, this is my DD, and I just need it to DD again. My next step, when these new rotors die, is to order a Granada swap kit, and modify it to fit. I figure with the new rotors, I have a few years to acquire the parts to do it all at once, and be done with it.
I wish I had taken pictures of my balljoint retrofit, but when bolted to the control arms, the grinding needed is self explanatory. I found a reference to it working elsewhere here, and rest assured, it does. The only drawback is that when they die, the entire suspension would have to come apart to fit replacements. Hopefully they last. lol
Also, something I couldn't find here (information wise) that has unfortunately cost me the price of another alignment, is strut rod bushing tightening/torque. The answer is succinct (via a classic Mustang forum): Tighten them until you run out of thread. I put this in this post in the hopes of saving someone else the expensive guesswork. lol
One more: Again, hard to explain, but it regards control arm bushing replacement. A little finesse with an air chisel, and they  came right out, even being the original rusted-solid stockers. Just take your time. Same with the rivets on the ball joints (also original)...I had bare control arms in about 15 minutes, just took my time, and paid attention.
bbobcat75
I WAS TRYING TO REMEMBER WHAT THE OVER ALL ISSUE WAS, THINK THAT THE 74-80 ROTORS WHERE TALLER IE FROM THE BACK OF ROTOR TO THE SPINDAL NUT, SO WHEN I TIGHTENED THE SPINDAL NUT THEY WHERE HITTING THE SPINDAL, PLUS NOT SITTING IN THE CALIPER CORRECTLY, I KNOW I DOUBLE CHECKED THE BEARINGS AND SEALS, THE USE THE SAME SEALS BUT DIFFERENT BEARS, NOW I DIDNT TRY TO SWAP BEARINGS, NOW IM THINKING I SHOULD HAVE.  IF I REMEMBER ANYTHING ELSE WILL POST AN UPDATE.
IF YOU FIGURE OUT HOW TO USED THE NEW ROTORS ON THE OLDER SPINDALS PLEASE LET ME KNOW WILL CONVERT MINE WHEN NEEDED, NOT INTO PAYING OUT THE @SS FOR STOCK NON PERFORMANCE ROTORS!!!
TAKE CARE
jeremysdad
Well h***fire. lol Guess it's time to drop back and punt. Thanks, guys.
bbobcat, do you remember where/what they may have been hitting that was preventing them from turning? I can so live without dust shields, if need be. :) Sorry for the questions, but I really don't want to have to have it apart sitting on stands for another week while I experiment and  figure out what to do with it. :)
bbobcat75
thses brakes are a pain, i have a 78 wagon ordered new rotors for , no big deal they are the same from 74-80! well some one before i bought it installed 72-73 spindals and rotors but i have the 74-80 brake calipers, tried to use the 74-80 rotors but when i got to tighten the spindal nut, they didnt spin didnt fit for nothing, got a set of 73 rotors and bolted up great!! not sure what the over all difference is but there is one!!!
good luck!!!    and the 71 -73 rotors are way!!! over priced  the cheapest i found was $110 a piece and they are so small and thin!! what a rip!!! o well, just venting!!!
take care
Pinto brakes are all the same regardless of body style. So any 71-73 brake parts should fit your wagon.
I checked Rockauto.com and could not find disc brakes for a wagon. I'm not sure why. The sizes for the non wagons between 1972 and 1974 are  the height 3.79" for the 1972 (non wagon ) and 3.91" for the 1974, also the thickness is different NOM thickness is 0.75" for the 1972 and 0.88" for the 1974. Also the hub size is also different 2.43" for the 1972 and 2.51" for the 1974. I do not know if they can be machined to fit. So what is the difference between the wagons and the rest of the Pintos for that year ? Take your hubs in to a machinist and have them measure it out. The specs are on Rockauto.com and when you click on the info wiki it should pop up with a parts diagram from centric. I hope this helps.
