Pinto Watch
Date: 06/22/2019 07:12 pm
Date: 02/28/2018 09:18 am
1973 Pinto Pangra
Date: 07/08/2019 10:09 pm
Date: 09/15/2019 12:38 pm
1980 Pinto w/ Trunk
Date: 08/10/2022 04:09 pm
Date: 02/04/2018 08:26 am
Cruiser Dash Gauges
Date: 12/04/2016 11:50 am
Pinto wagon Parts
Date: 06/23/2021 03:25 pm
1977 Front Sump 2.3 Oil Pan
Date: 09/14/2018 11:42 pm
  • Online today: 2,612
  • Guests: 2516
  • Total: 2516
Which clutch are you running?
Started by wymanj, May 25, 2013, 08:52:32 PM
Most of us have installed T-5 trannies using either the D5, D9 or bellcrank bellhousing from Fox Mustangs & are running the turbo clutch with it. Mine is from a turbo coupe but they are pretty much the same.
You may have to look into a ministock clutch in order to use the stock Pinto trans. I know they handle 300HP & are stock appearing to comply with rulebooks.
wymanj
I have a 2.3 turbo from a merkur in my vehicle with the stock pinto bell. My 8.5" clutch didn't last long so ordered a spec stage 2 clutch (9") and the pressure plate hits the inside of the bell before getting tight. What clutch are you guys running that works with the power of the turbo and within the stock pinto bell housing? Thanks, Jordan.
