pinto for sale
Date: 09/11/2016 09:47 pm
Clutch Fork
Date: 03/31/2018 09:12 pm
Anyone scrapping a 1980
Date: 03/13/2020 08:46 pm
Date: 06/07/2021 08:14 pm
2.3 front sump oil pan
Date: 02/19/2017 03:24 pm
78-80 Windshield
Date: 10/29/2021 03:11 pm
Mustang II V8 swap parts
Date: 03/26/2017 02:25 pm
2.8 radiator
Date: 10/25/2019 04:10 pm
72 pinto
Date: 06/23/2016 12:40 pm
  • Online today: 788
  • Guests: 920
  • Total: 920
my 1977 pinto wagon build
Started by simon o, May 12, 2013, 10:07:21 PM
bbobcat75
sent some pics of the quarters for ya!!
thanks
1975 mercury bobcat 2.8 auto
simon o
i got the dart tall deck block in and mocked up had to drop the transmission mount 11/16 for header clearance at the collectors. other then that everything else fit great
i got a set of fiberglass front fenders will need to get the hood next. the fenders look like they mite need some work to fit.
found a local place that does ceramic coating i will get them to coat my headers after i get the O2 sensor bungs welded in
1977 pinto wagon
simon o
finished building a brake pedal and mounting the brake booster and master cylinder
got my new jesel shaft mount rocker arms offset .450 intake to fit my AFR 227 competition eliminator cylinder heads
i am going to order a gm metric 11'' brake kit from speedway motors they seem to have good prices. that will be the last thing i need to finish my brake system
1977 pinto wagon
simon o
1977 pinto wagon
bbobcat75
WHATS THE E-MAIL ADDRESS YOU WANT THEM SENT TO??
THANKS
BBOBCAT75
simon o
Send pics when ever you get a chance. I am in no hurry.  Thanks
1977 pinto wagon
bbobcat75
can send pic, and can ship to canada on your dime!!! :)
simon o
bbobcat75 i will look at my quarters this week and figure out what i am going to do. the quarters are in good shape except for around the wheel wells where they have had some pieces welded in before. i need to section about 3" in them for tire clearance i am running 33 by 19.5 tires on a 14" wide rim.
if you have quarters in decant shape mite need some pieces out of them if you ship to canada
1977 pinto wagon
bbobcat75
on the other side of the earth from you simon but have a 73 wagon i am parting out, if you need body panels have no problem cutting it up to get you the parts you need to finish that bad @$$ car of yours!!!
take care
bbobcat75
simon o
your car is looking good bud. originally i wasn't going to do the front frame. but it gave me so much more clearance around the engine.
i am stuck on a couple things now haven't figured out what i am going to do with the rear quarters and wheel wells i need to section a piece in them they have been fixed before so be nice to find quarters from another car or new panels.
i change my engine combination and got a tall deck dart aluminum block. built the headers for a standard block. headers fit with this block but oil pan will be close to rack
will be starting on the rad support next and once a get a 4" stroke crank i will start on building a aluminum oil pan
1977 pinto wagon
79prostreet
Simon, wow can I relate to how much work has been done and how much work is still to go. check out my gallery and you will find almost a twin of what you are doing, just didn't do the front frame. keep posting pic's so i can get good ideas for my son and my build. Bud ( aka 79 prostreet)
79prostreet
simon o
1977 pinto wagon
simon o
Thanks its been a ton of work to get it this far and got lots to go I am happy with the way things are going. I was hoping to be farther along then I am but I have made some changes and redone a couple things.
1977 pinto wagon
bbobcat75
man that shot of the rear end with the tires is awsome!!! thought about tubbing my wagon, but its a ton of work!!!  looks great!! cant wait to see the finished project!!! keep up the great work!!!
simon o
i have had this car for around 8 years now. i put a 5.0l with cleveland heads paxton supercharger 12psi c6 8.8 rear. drove it for 3 years and split the block in first 3 mains into cam journals and cam bearings fell out.
so i started a new build on it. been working on it for 2 years now
its been a lot of work been doing it all by my self and have a lot of work to go
1977 pinto wagon
