Date: 09/15/2019 12:38 pm
1973 Pinto hatchback for sale
Date: 11/13/2023 11:30 am
Date: 10/15/2017 10:03 am
Date: 08/17/2022 06:27 pm
Date: 03/07/2017 07:03 pm
Rare parts for sale
Date: 09/10/2018 08:38 am
Misc. Pinto parts
Date: 11/09/2019 04:25 pm
Date: 02/18/2017 04:41 pm
Date: 09/06/2020 01:57 am
  • Online today: 1,090
  • Guests: 92
  • Total: 92
door crash bars
Started by 79prostreet, May 05, 2013, 07:44:16 AM
simon o
i drilled the spot welds in mine and cut the bar in 3 pieces thru the access hole. it probably would have been easier to do it the way you did . i think it is worth the little bit of work.
1977 pinto wagon
79prostreet
Well I removed the crash bar from my drivers door, not for the faint of heart! As the pictures will show the bar gets wider and taller in the middle area, so as I went the hole became larger and wider. All in all I'm pleased with how it's turning out,well worth the weight loss. With the door being 53'' long and that bar to add to the over all weight, I can see why hinge bushings wear out.
79prostreet
I experimented on a pair of junk doors with the latches, rods, glass & tracks removed. Using my Sawzall with a long (10" maybe) metal blade I was able to cut through both sides & remove 95 percent of the brace rather easily. A die grinder & cut off wheel works well if you are patient & careful.
This link shows removal via the the rear, your idea of removal by the hinge side sounds less conspicuous.  Thought I read that somebody snuck in there with a die grinder using a cut of wheel and removed most of the bar in pieces leaving just the spot weld portions in place, but could not find the link.  I assume this is for race car use.
http://www.fordpinto.com/general-pinto-talk/door-help/msg63866/#msg63866
79prostreet
Has anyone pulled the crash bars out of your doors?  I'm thinking of cutting the front open, drilling the back spot welds and pulling it out then make a pc to cover the front hole.
79prostreet
