Date: 01/24/2021 07:54 pm
1974 Ford Pinto Squire Wagon
Date: 05/30/2020 01:51 pm
Date: 04/13/2017 04:56 am
Need 2.3 timing cover
Date: 08/10/2018 11:41 am
1971-1975 Pinto
Date: 01/09/2017 04:14 pm
1976 Ford Pinto
Date: 07/16/2019 02:51 am
Date: 01/21/2023 04:19 pm
Date: 01/20/2018 07:51 pm
Date: 02/05/2017 09:45 am
  • Online today: 531
  • Guests: 460
  • Total: 460
new radio installation
Started by r4pinto, June 07, 2005, 10:41:11 PM
pintoman
As an expert[heck of a long word for me ],it is best to find a constant 12v souce at the fuse box.If that isn't possible go right to the possitive side of the battery and use a 7.5 amp fuse[at the battery].If done right you shoudn't have any problems.Run the wire through the fire wall, do NOT run it through the door jam,your looking for trouble there.Use the factory plug for the ing. lead and ground.If the gruondis not at the plug ground it to the back of the dash.Then all you do is hook up the speaker leads and you should be done.
I can't tap into the lighter for power. Mine wasn't built with a lighter. I tap into the fuses for the original radio & the brake lights.
I usually try and tap into the lighter for a constant 12 volt source.
12v+ constant i got from the headlight fuse on the fuse panel. ground the black one, hook the red one to switched 12v+ and run speaker wires. Shouldnt be any drains in a perfect world.
be sure that it wasnt something else draining the power, even though there is a small small chance it would be that.
Had mine hooked up how i described and worked everytime.  Let me know how it goes.
-chris
1971 Pinto
I am in the process of fixing my pinto's interior & will be putting a factory type cassette player in it, but in the mean time I'm installing a cheapy radio I picked up for 20 bux at the junk yard. Anyways I wired the speaker, power & ground leads & then hooked the yellow wire for the memory, which I plugged into a hot source in my fuse box.
I was able to retain the memory, but after I got off work I went to the car & the battery was dead. Am I doing something wrong? To those of you that have installed a modern radio into the Pinto, what did you tap into for the constant power?
Any help will be appreciated.
