Date: 04/27/2018 10:28 pm
Date: 04/10/2017 07:30 pm
Date: 01/23/2023 02:22 pm
Date: 11/04/2018 02:34 am
2.3 turbo intake (lower)
Date: 07/15/2020 09:29 pm
convert to stick
Date: 05/19/2018 09:26 pm
Date: 02/18/2017 04:47 pm
78 hatchback
Date: 03/12/2023 06:50 pm
  • Online today: 1,972
  • Guests: 94
  • Total: 94
Upper control arm squeek
Started by Jerry merrill, April 05, 2013, 07:25:52 PM
DBSS1234
Try greasing your upper and lower ball joints. I thought my Mustang II had squeeky control arms too, greased the ball joints and it fixed the problem!
The stock rubber bushings are designed to operate without lubrication.  There are no intended sliding surfaces.  Be sure that the A-arm is at its normal ride height before torquing down the cross shaft end nuts, this is to avoid preloading the rubber.  As to the squeak, maybe something loosened up.
Jerry merrill
I used stock rubber bushings, but is there no way to lube them on a regular basis and you can't put very much lube on initial assembly.
What kind of bushings are you using? I installed new poly bushings last year on my 78 and they squeek a lot compared to rubber.
Jerry merrill
The upper control arm on my 71 pinto squeeks loud after about 100 miles on a new cross shaft. I lubed it up on assembly but dont see anyway to lube it once together. Any ideas?
