Date: 11/02/2019 10:25 am
Date: 12/31/2017 09:03 pm
Date: 02/26/2017 03:22 pm
Gas Tank Sending Unit
Date: 05/22/2018 02:17 pm
73 Caliper Retaining Key
Date: 10/28/2021 07:49 am
Date: 02/28/2018 09:37 am
Date: 04/25/2017 12:17 pm
1976 Ford Pinto
Date: 07/16/2019 02:51 am
2.3 turbo intake (lower)
Date: 07/15/2020 09:29 pm
  • Online today: 178
alternator question
Started by waldo786, April 01, 2013, 08:27:12 PM
waldo786
I did see that as well, but I think it'd just be easier to do the one wire right from the battery.  I wouldn't know all the wiring to remove so I'll probably just wrap it into the harness.
Yep, and you can either eliminate the stock alternator/regulator wiring or just tape it up & wrap it into the harness & leave it incase you ever need it again.
That single wire can also be run to the solenoid where the battery cable connects instead of direct to the battery if you prefer.
waldo786
I seem to have found an answer to my own question here.  Basically you just hook up a wire to the positive battery terminal to the one wire hook up on the alternator and voila! there you have it.  Recommended 8 gauge wire for 4 feet and 100 amps.
waldo786
I am planning on adding aftermarket A/C to my car and a previous owner already upgraded the radio, so I was going to get a 100 amp alternator for my car.  The 100 amp though is a one wire alternator and I wasn't sure how it would hook up as there are three wires connected on the stock one.  It is listed as fitting this make and model of vehicle (a 1976 pinto with 2.3L).  Any thoughts?
