Date: 09/12/2018 12:33 pm
Date: 08/06/2021 02:23 pm
Need 2.3 timing cover
Date: 08/10/2018 11:41 am
Need Clutch & Brake Pedal
Date: 12/23/2016 06:16 pm
1980 Pinto Wagon
Date: 02/29/2020 07:01 pm
Automatic Wagon
Date: 06/14/2019 11:22 pm
Date: 12/09/2018 06:59 am
Misc. Pinto parts
Date: 11/09/2019 04:25 pm
Pinto for sale
Date: 04/19/2017 10:15 am
  • Total Topics: 16,268
  • Online today: 673
  • Guests: 525
  • Total: 525
Compression Ratio
Started by tbucketjack, February 23, 2013, 01:45:11 AM
tbucketjack
Just want to thank you for the inputs. Valve stem seals it will be. Thanks again. :)
Your compression is fine , change your valve seals.......
fast64ranchero
As stated above, it's valve stem seals, The  2.0L has a flooded top end and the valve stem seals are an issue if old or not installed correctly.
You can do them without pulling the head by making a fork tool to compress the valve springs.
72 old V-8 parts Pinto
73 pinto, the nice one...
wbacon8780
Valve seals will cause the blue puff. Seals are no good and oil gets by them and leaks into the cylinder, when you start it you get your blue puff.
tbucketjack
I just did a compression test on my stock 1971 2.0. I got: 145, 147, 145, 145 on a warmed up engine. Then I did the wet (oil) test and got:   145, 152, 145, 150  I normally get blue smoke on start up and she will puff out sometimes while idling. Is this compression too low? Could the smoke be from valve guides or the seals? Thanks
