Date: 06/07/2018 01:45 am
Date: 12/09/2016 08:34 am
Date: 04/30/2023 04:31 pm
Date: 01/21/2023 04:19 pm
72 Pinto
Date: 03/07/2019 12:07 pm
77-78 front grill
Date: 04/07/2017 12:35 am
78 windshield trim
Date: 02/01/2020 08:46 am
2.3 front sump oil pan
Date: 07/24/2018 03:17 pm
Anyone scrapping a 1980
Date: 03/13/2020 08:46 pm
  • Online today: 445
  • Guests: 395
  • Total: 395
Fuel level sender
Started by wbacon8780, February 06, 2013, 04:49:14 AM
72pair
@HOSS: The 71-73 mustang sender is still only 1 fuel line albeit is 3/8". What I was referring to is the wiring. My 72 connector plugged right up and worked. I've got the fuel pump return plumbed into the factory vent on top of the tank on one car( after drilling out the fitting), and use a vented cap. If anyone is having float troubles get one from Dennis Carpenter. Its a solid design and compatible with new fuels and its 5 bucks.
289Wagon
Before you spend $ on something you may wish to do some easy testing. Most often the problem is the sender there is also the wiring,CV regulator and the gauge itself to consider.
1) As HOSS429 said check for low or intermittent voltage at the sender. That will show if the wiring & CV regulator are ok.
2) Verify that you have a good ground thru the ground wire in the connector to the body. (I think it goes to a screw attached to the nearby cross brace.
3) And then using the method us old folks did when we didn't have all those fancy tools,
The way to test the gauge is to unhook the wires to the sender and the gauge should read empty. Now, ground the sensor wire and the gauge should go all the way past the full level. If this happens your wiring and gauge are fine.
If you should need a sending unit, there is a NOS one on Ebay for $59.99 w/free shipping.
HOSS429
Quote from: 72pair on February 07, 2013, 02:29:33 PM
Got 71-73 mustang sending units in both my 72s. Had to trim the notches in the tank a little for the tabs on the sender. IIRC the 69 sender has only 1 terminal. The 71-73 terminal matched the pinto.
good info .. yes i saw the 69 had no return fuel line .. i was going to find a vented cap ..
289Wagon
later units
289Wagon
Early units
wbacon8780
72pair
fast64ranchero
When you have it out check the float, it may be sunk, (full of fuel) and use a ohm meter to test the sender.
72 old V-8 parts Pinto
73 pinto, the nice one...
289Wagon
  What year ?   What model ?
wbacon8780
Thanks Hoss..let us know if it works.
HOSS429
another thing .. i have yet to do it but i purchased a new sending unit made for a 69 mustang and will attempt to make it work in one of my pinto`s .. the shape is very close ...just need to get a  good tank ...
HOSS429
unplug the wire connected to the sending unit and test it with a test lite .. the wire should make the test lite blink i think ...with the switch on of course
wbacon8780
I haven't taken it out yet. All I know is my gauge don't work. I will order a seal/ring kit and filter..... Thank you
While your on eBay get the seal/ring kit and buy a filter for the fuel inlet. Your car will thank you. Also have you tested the fuel sender and the wiring to ensure it's at fault ? Some times they get stuck from not being used, removal and cleaning sometimes will help in fixing the sender.
I picked up an NOS sender for my '80 on Ebay a year ago for $60 bucks shipped. Keep your eyes peeled & get a good Ford part. They are out there.....
wbacon8780
Looking for a fuel level sender. Are there any aftermarket brands that will work?
