Date: 09/22/2020 11:33 pm
pintos for sale
Date: 12/11/2018 04:29 pm
1971 2.0 valve cover
Date: 01/25/2019 07:09 pm
1980 cruising wagon ralley
Date: 07/12/2019 01:41 pm
1980 Ford Pinto For Sale
Date: 07/01/2018 03:21 pm
Date: 10/26/2020 03:24 pm
Alloy Harmonic Balancer
Date: 07/10/2020 12:17 pm
Interior Parts
Date: 08/07/2017 03:59 pm
71-73 Front Kick Panels
Date: 04/25/2021 07:24 pm
  • Online today: 782
  • Guests: 779
  • Total: 779
Grille interchange
Started by fairlaneracer, January 25, 2013, 09:36:46 AM
JoeBob
77 yellow Bobcat hatchback
Deuteronomy 7:9
James Meter
JoeBob
There is an easy way to draw the fat bumpers in to fit flush, if that will help. I did it on my 77. I showed a step by step in one of the forums. If anyone is interested I will look up the link and post it.
Deuteronomy 7:9
James Meter
I've got a '75 (vertical & horozontal bars) that I've put a '74 (vertical ribs) grille on.
Also gonna drain the bumper shocks to move the bumper closer to the car. Hope I helped a little@!
I believe a 74 or 75 grille will interchange with your 76.  74 was the first year of the cable hood release.  The 71-73 cars had a manual hood release so the grille is different and would probably have to be modified to work on your 76.  I believe the early bumpers will bolt on with some fabrication however the front valance will have to be modified to clear the larger radiator support frame.  There is a pink 79 or 80 that was converted years ago.  If I remember correctly he showed what needed to be done for the early front end in his thread.  Sorry I forgot his screen name.
Pinto1600
It can be done,but alot of fabricating! Good luck! Early Pintos had solid frame work,after '74 shock absorbing -heavy mounts and differant trim. The grille also mounted differantly.
Happiness is..Driving a classic Pinto
fairlaneracer
Looking for info. I have a 1976 Pinto and looking to convert the front and rear to look like a 1971. Will the grille and bumpers interchange? Please Help.
