parts needed
Date: 02/20/2017 07:58 am
Date: 08/22/2018 09:23 am
Date: 09/05/2018 06:30 pm
Pinto Watch
Date: 06/22/2019 07:16 pm
Date: 06/28/2019 09:14 pm
Squire trim
Date: 03/28/2018 10:11 am
1976-1980 A/C condensor
Date: 09/21/2020 10:43 pm
Pinto Vinyl Top
Date: 10/09/2020 10:29 pm
Date: 10/14/2019 08:24 pm
  • Online today: 969
  • Guests: 1007
  • Total: 1007
What did you do with/to your Pinto today?
Started by pintogirl, November 10, 2012, 08:35:18 PM
Used the last warm Ohio day to sort out my new parts for Callisto & put them in 3 large boxes. Also stacked my single seat frame on top of my 4 seat rail to clear some floor space. Man was that a mother without help....
All that's left is roll her in & get to it  8)
I had almost 6 hours before work today so I got busy.
I saved both quarters with hopes I'll never need them. This one was decent compared to the driver side but will still need work if I ever have need of it.
Going, going......
GONE!!!!  Whew, now I gotta clean this mess so I have room to work.
All the parts I need to use are off to the side & all the extra pieces are in my shed incase they are needed.
went home at lunch friday and got the wagon out, hosed it down, dried it off and drove back to work...... saturday drove the wagon some more and pulled the 75 trunk out to clean the fuel filter and then put them both back in the shop....it was in the 70s both days.....:D
racer99
Pulled the exhaust manifold looking for an exhaust leak.
Found the last guy did not have the manifold to pipe studs
run all the way up.So the ball and socket flange wouldnt
pull up to stop the leak.
So after getting the stud out,it is metric on one end and standard
on the other.
12mm x 1.75 on the manifold end and 7/16 x 14 on the pipe end.
Gotta love Ford.
Its fixed with 2 12mm x 1..75 x 2.5 long bolts.
earthquake
Quote from: bbobcat75 on December 02, 2012, 09:14:27 PM
man keith you are not playing around you are working like a mad man on those cars!! i was in ohio last month and it was sooooo cold i didnt even want to go outside!!! take care and talk soon, still want those parts!!
eric
No problem, just let me know. Yeah, I need this car outta my way so I can use my garage again.
eric
Spent friday tearing the '77 apart. Got the crossmember cut out to install on the '73, saved both inner wheelwells & got the floors out in 2 sections to repair the rusty ones in Callisto.
Another couple days work to finish it off, some garage cleaning to do then Callisto comes inside so I can get busy. I have about 5 months to get her back on the road so I want to get started.
Quote from: cabecho on November 19, 2012, 06:06:12 PM
they were good but not any more. lol
if you need one i can probably get you one. i have a hard top if you want one.
I would love to have a hard top for "my" Miata, but they are expensive and the shipping would be a killer! LOL
I'll PM you about the soft top.
cabecho
Aerodynamics is for those who can't build engines
If ford pintos are not fast then why chevy's have to use there parts to make them fast?
Quote from: cabecho on November 18, 2012, 05:28:05 PM
Friday pack everything from the pro-street and all the tools. sat. destroy 2 Mazda miatas, and take the pintos and tools to the new shop. today still moving things from one shop to another. i hate moving the shop.
If either of those 2 Mazda Miatas have good tops, I'll take one! LOL
I spent about 14 hours over the last week stripping the '77 parts car. I'm re-using nearly the entire car to assemble my other 3 so I'm saving every nut & bolt. This is gonna take awhile.....
cabecho
Quote from: pintogirl on November 12, 2012, 06:58:18 PM
Well I know that both upper and lower hose get warm. So I am guessing it is flowing right? I will check the door. I'm pretty sure it is closing all the way, but I will make sure.
The hoses will still be warm with air trapped in the core. This issue has driven me nuts on my ex-wifes '02 Villager. I finally put a flush/fill connector in the heater hose & I fill it with a squirt bottle to get the heat working.
My guess is the door is hanging open a little though.
Quote from: Pinto5.0 on November 12, 2012, 06:11:35 PM
2 things to check. First make sure the water flows from the engine to the bottom heater core tube then exits the upper. This keeps the core full & removes trapped air. Then make sure the air door that the cable moves from cold to hot is actually moving fully to the hot position. If it's part way open it allows cool air from the cowl into the heater.
Quote from: pintogirl on November 12, 2012, 02:08:42 PM
Drove mine to work last night. Was the first time being able to use the heater since I put the heater core in over the weekend.
Question, how hot does a Pinto get when it comes to using the heater?? It took mine about 10 miles (half way to work one city streets, 50mph avg.) to even feel somewhat warm. I would say it only got to about luke warm the whole time. On the way home it seemed to blow warm air faster ( only had  4 hours between parking and going home) but again, it never got over luke warm.
I'm thinking maybe it is missing it's thermostat. Causing it to not really get warm in the time it is running. Takes me roughly 30 mins give or take to get back and forth to work. Hate to say it, my VW bus warms up and blows hotter then my Pinto! LOL
DreamBean
SAT:Well, I drove the turbo 80 to the parts store to get a new fuel filter for the 76. Then I removed the broken fuel filter  from the carburater of the 76.(Don't Ask)
Today: 76 run like Crap, Cannot get it to stay running.( Drove it around 50 miles to and from work this way) Boy oh Boy was that fun.
Tues: Will be driving the 80 turbo back and forth to work till Saturday.
Go Ford, Go Fast Or Go Home!
We removed the seats/ carpet / and am disassembling the dash. cleaning the floors and doing rust repair.
74pintoguy
I got mine ready for the trip to DE to the new owner...hate to sell it, but hate letting it sit, too.
Pinto1600
Put both cars up their skates,pulled the batteries ,topped off the tanks,and covered them up. Good night until late Aptil 2013.
racer99
Sat in the wagon Sat. and made motor noises as it is
awaiting more parts for the turbo motor.
Thursday & friday I sorted parts & filled Callisto with all her goodies & the '74 wagon body that Pinturbo75 brought me last week with everything else Pinto to clear my garage. Now I can strip the '77 parts car & '87 Mustang parts car indoors this winter. When those are chopped & scrapped I can pull Callisto inside & get some more work done.
Today I ran around in the '76 wagon a bit before taking it to work. There it will sit for a month untill my semi needs serviced.
cutelitlputtputt
Quote from: blupinto on November 11, 2012, 03:28:46 PM
JENNIFER!!! PUT SOME FLUID IN THERE FOR THE LOVE OF DOG!!! NO WONDER SHE"S MAKING NOISES!!! YOU'LL MESS UP THE TRANNY!!!
Becky, you crack me up!  I actually read dog as God!
But the Pumpkin and owner look like rubes when there are leaks under it!  Of course, now she sounds like a hillbilly rube car!
I suppose I could put some in, but it will come right out!
:P
Anything to keep her runnin'!
bigfoot
Looked at the snow outside and then went in the garage and rolled up the driver's side window. There is always next year.
1976 runabout
1978 turbo
2000 electra-glide
Today I pulled out the instrument cluster of Moxie Blu (pictures later) and attempted to clean out her cowl (not very successful) but STILL NO KEYS!!!
Alas, I have to go up to Dad's place, so I can't do much more for now.
cabecho
 :oHolly cow. I have to side draft and I'm always complaining when I go to the track or even start the car. I can't complain any more.  :-X
I did have a tunnel haul race boat. Talking about tuning it had 9 carbs. !   Fred
cabecho
Yesterday started one of them up and move it out side the house , made a few laps around the block before parking it, so That his other brother it can start been taking the motor apart and getting it ready for the stampede.
I spend like 2 hours tuneing it because Is running really bad. I hate that the webers got to be tune every time you want to drive it.
cutelitlputtputt
Becky, you're gonna die...I mean die!!!  I mean die because you understand cars more than I do.....
no, I have not fixed the transmission.  No money.  I just don't put any more fluid in it because it leaks as fast as I put it in!!  I mean, you know, it messes up parking lots and people's driveways and stuff. That is not cool.
She is making some weird noises down there now!!!!
I have been driving around a long time like this......Beck y, I was going to get it fixed but then situation at work changed.  That was my next thing I was going to have fixed, even before the leaky waterheater at my home!
