Date: 03/06/2017 01:24 am
Date: 05/19/2018 04:56 pm
1980 Ford Pinto For Sale
Date: 07/01/2018 03:21 pm
Date: 01/28/2017 12:30 pm
Date: 11/11/2019 04:49 pm
Date: 04/15/2017 05:14 pm
1977 Cruiser
Date: 06/29/2019 06:28 am
1976-1980 A/C condensor
Date: 09/21/2020 10:43 pm
1976 Ford Pinto Pony
Date: 09/06/2018 05:40 pm
  • Online today: 687
  • Guests: 701
  • Total: 701
What did you do with/to your Pinto today?
Started by pintogirl, November 10, 2012, 08:35:18 PM
It sounds like you got Pumpkin's leaks fixed!!! YAY!!! ;D
cutelitlputtputt
I'm going to wash mine today when it warms up.  Right now it is like 42 degrees!
Then I will put her to bed, she needs a rest after going back and forth from Yucaipa to Glen Helen for six days straight!
Anything to keep her runnin'!
mrskydog
I washed ,detailed and waxed one more time before winter. :( Took it for a drive nice day....parked in the garage and covered.....Kirk
"Living the Dream...Driving Old Fords"
1965 Mustang 2+2 Fastback
1980 Pinto Rallye 32,000 Org.
1972 Maverick Grabber V-8 car
2005 Mustang
D1
Drove mine to work yesterday and gonna drive it to Church today  :D
May the Lord bless
Romans 14:11(KJV)
sedandelivery
I took mine to the hardware store and then to my nephews. Trying to take advantage of the time before the snow starts.
Quote from: beaner on November 10, 2012, 10:58:33 PM
i opened the garage door and let the light touch it ;D ;D
brad :)
That's more than I did with mine, although it did see a little sunlight last Saturday!
Dwayne
cromcru
im in the middle of installing my 93 2.3 t5 into my 74 pinto station wagon.i started the install using my 75 mustangII d5 bell housing but due to not getting enough adjustment to engage the clutch properly im now installing my foxbody bell housing.and from test fitting shows to be alright. everything went in fine.using my t5 driveshaft,front u-joint for 93 mustang,rear u-joint from 75 mustangII 2.3..only other issue i see is the speedo cable.im going to take my pinto one in and have the bottom half change over to the t5 style..when i got my d5 bell. it came with the spacer plate, bellhousing, clutchfork,throwout bearing and clutch ball stud. it did not come with the flywheel.i dont remember if the 75 model year used a small spacer behind the flywheel or a thicker plate.ill report more later
79 bobcat  78 ford pinto station wagon   93 ford mustang lx   90 ford mustang cont lx  63 chevy truck    52 studebaker 2r16a
Last week I not only let the sunshine touch some of my Wildfire buried in the garage, but I had to go on an expedition of sorts to get to her driver side door to open it and retrieve the '74 Pinto owner's manual out of her glove box to put in the '74 Squire wagon. lol
brad :)
LOL, sometimes that is more then what I do to mine in a day! LOL
beaner
brad :)
pintoman1972
As a matter of fact, today I decided to take the valve covers off, pull the plugs out and go through the valve train.
This 612 HP V8 302 motor has a Hartland Sharp top end with 3/8 screw in studs, guide plates, 1.6 to 1 roller rockers and stud girdle.  The valve lash is adjusted to zero for the high lift hydralic roller cam, and then locked down at 1/2 turn past zero.
Did the compression check on each of the 8 cylinders. Driver side varried between 155 and 165 PSI with very minimul leak down.  Passenger side varried between 160 and 170 PSI also with minimum leak down.
SO all is well with the top end and with the pistons.  Tomorrow will put it all back together.
DIck
I didn't do anything to ANY of my Pintos today except drive a reluctant Ruby RedHot to Starbucks and later Ralphs store. I WAS going to clean out Moxie Blu's cowl out (you can probably imagine all the stuff sitting piled in there after years of living under a pine tree) but I can't find her keys!!! AAAARRRRGH!  I had them earlier this week but who knows what I did with them!? I know I needed to "batten down the hatches" due to the rain my area was expecting but the keys disappeared since.  I was planning also to remove her instrument cluster again and see why the lights don't work but even if I could find the keys I may be going up north to help my Dad and his wife move house.
Original74
I just had my carb rebuilt and had to fine tune the fast idle screw and then the curb idle. Now from a cold start, just set the choke with a quick pump, sit back and hit the key, she fires up on full choke, light tap and she comes back down to a fast idle with a little choke. After about a minute, another tap brings her down to the last step on the fast idle cam, ready to drive. Nothing sweeter, I love it!
Dave
1976 Runabout, project.
I put a new car cover on my blue 73 and aired up the tires.
Quote from: Fred Morgan on November 10, 2012, 08:58:42 PM
Kim ask Bob he knows I take them to 16 pounds.   Fred    :)
I just hooked mine up to the car as seen in the pic. Figured after 10 mins. of running and not leaking, it was good to go! :D So far so good! :D
Quote from: 78txpony on November 10, 2012, 08:49:37 PM
Today mine was actually uncovered and driven for the first time in 6 months.  It is my winter driver.    Car ran well i just had to get used to it again. I had to relearn driving a stick...
I'm lucky, my yellow one is an automatic. :D  If things go well with it this week, I may end up driving it to work and back all winter too! :D
78txpony
-Rob Young
1997 H-D Sportster
Quote from: Fred Morgan on November 10, 2012, 08:44:02 PM
Kim I always pressure check rads and heat cores first !   Fred    :)
Thanks Fred! Fine time to tell me now! LOL It only took one time to learn on this one. :D
I thought this may be a fun topic to start here. They do it over at a VW site I go to and it is a lot of fun to read what others do. It also gives someone that doesn't want to start a build thread on their Pinto, a chance to share what they have done.
I'll start if off. :D
Today I installed a heater core in my Yellow Pinto, TWICE! LOL
When I first got the car it was missing the heater core and the front cover to the heater core box. (Don't know the name of that box! LOL) So today I got into the Pinto shed and dug out another box. I got the heater core out of the box and went to put it in mine. Then I realized that the heater core doesn't stick through the cowl. UGGGGGHHHH Had to pull the remainder of my box out of the car. That was not fun. Got it out, put the new, aka used, heater core in and put the cover to the parts box on my box. All good! Installed it all back in the car, again, not fun.  Pretty much had it all hooked up and drip, drip, drip. UGGGGHHHH. Out it came. Found another complete unit in the Pinto shed and here is how I decided to test it before I put it in the car. :D
I hooked up the water lines and started the car. Ran if for about 10 minutes, then once I was satisfied the heater core didn't leak, I proceeded to pull the old one back out and install the good one. When trying to put the new one in, I broke the ducting for the floor off the one end of it. Pulled it back out of the car and grabbed one off of the other box and finally got it all back together. No leaks! :D
We also pulled the broken windshield out. Tomorrow Jr. is going to come over and install a new one for us. Then I get to start driving it to work for a few days. :D
So that is what I did to my Pinto today. What did you do to yours?
If this thread takes off, I will see if we can make it a sticky. Want to see how it goes first though! :D
