Date: 04/24/2018 11:45 am
1974 Wiring diagram free
Date: 10/27/2019 06:56 pm
78-80 Windshield
Date: 10/29/2021 03:11 pm
13" Style Steel Trim Rings
Date: 10/09/2020 10:35 pm
2 Pinto Wagons for Sale
Date: 10/29/2018 02:02 pm
Date: 09/12/2018 04:07 pm
Date: 02/04/2018 08:26 am
Electrical
Date: 03/29/2017 11:37 am
Date: 06/18/2018 03:47 pm
  • Online today: 656
  • Guests: 517
  • Total: 517
1978 pinto engine tap noise
Started by tonij1960, October 25, 2012, 11:03:44 PM
bbobcat75
Had a new hyndia that the valve stuck till warmed up. Changed the oil n added Lucas n stopped the ticking.
1975 mercury bobcat 2.8 auto
ToniJ1960
 sorry if I confused anyone it was rebuilt about 30,000 miles ago. Thats more than a few years now since I dont put 5 or 6,000 a year on it. I had other cars over the tears too, but this one stayed with me.
I dont think the valves are adjustable but I can try that lucas treatment, I heard a few people say good things about Lucas. It gets good mpg though and seems to run fine other that that noise. Would a stuck valve get quiter after it warms up, and not cause more obvious issues?
bbobcat75
sounds like it could be a valve sticking. run some lucas oil additive and see if it helps if not then you know that its more then likly not the valves.
does it sound like its on the top of the motor or at the bottom?? if just rebuilt would think also that maybe a vavle needs to be adjusted.
dont know a ton about the 2.3, but on other motors i have worked on these tips have worked.
just my 2 cents
good luck
ToniJ1960
 Its a 2.3 with about 30,000 I guess, since it was rebuilt. The noise goes nearly completely away once it warms up did yours do that too? It is worse when its colder outside and goes away, so maybe its an exhaust leak even. How much do you think someone will charge to take the rocker cover off and look at it? Most of these places try to charge sky high and act as if working on an old car is harder. I always try to have some idea before I call around.
jeremysdad
From the recording, it sounds like what mine did with 3 wiped cam lobes. Hard to tell, really, from a recording. Is it louder above or below the motor? That's how I narrowed mine down. Also, when in doubt, pull the valve cover and take a look-see. That REALLY narrowed mine down to the valvetrain.
What motor is that, 2.3?
ToniJ1960
 My pinto is making a tapping noise, it goes away nearly completely once it warms up. I dont know if its the lifter cam or what. Someone told me it sounds like a wrist pin to him (he wanted to buy my car and may have just been trying to scare me).
I made some recordings so you can hear it running, and uploaded them. I hope Im not breaking any rules, this hosting site seems ok to me I made sure it was safe. You just have to go the url and then hit download filer and the captcha thing.
http://www.filedropper.com/sunp0061
http://www.filedropper.com/sunp0062
If anyone can tell me if they ever heard this noise or if its possible to get an idea what it is from t he  sound on the recording. I was thinking about trying a software analyzer to see if I can get a look at it if that could show its a wrist pin or not. I heard theyre like a double tapping from when the piston goes up and starts to go down.
