6.6.75 carrier
Date: 02/14/2018 06:47 am
Date: 10/01/2020 02:00 pm
Radiator
Date: 05/27/2018 06:07 am
Rally spoiler wanted
Date: 05/04/2017 01:32 pm
Misc pinto parts 71-73 2.0
Date: 05/05/2020 11:56 pm
Date: 10/24/2018 07:41 am
Great Cruise wagon
Date: 12/17/2016 03:39 pm
Date: 03/13/2021 12:57 pm
Oil pan front sump style
Date: 01/10/2017 09:19 am
  • Online today: 826
  • Guests: 631
  • Total: 631
Holley 350 cfm restrictor kit
Started by MitchiePinto, October 15, 2012, 05:36:21 PM
MitchiePinto
Thanks for your comment, I think Il go with a holley 5200 re-manned from Napa just need the adapter plate
I believe it leans out the mixture at an idle so you dont load up.  I installed one in my 500cfm.  It was pretty easy.  Just make sure you drill straight.  While i am still a little rich at an idle, it is much better than it was before.
MitchiePinto
Currently I have a 2100 Motorcraft that is toast I rebuilt it and it runs but noticed after rebuilding it a vacuum leak coming from the throttle shaft output and there is lots of play in the shaft, latter found out that this is a common issue from wear and tear and requires a whole new carb.
I was given a 2150 off of a 318 and found it to run to rich and not idle so I removed the power valve and used a #16 power valve off the 2100 and it solved the issue but still not running right I noticed that it has external vacuum running off the power valve cover ? should I connect this to my manifold tee but theres gas running though there? is gas suppose to run under the power valve or should it be dry
Or should I just buy a Holley 350 cfm and order a restrictor kit and right sized PV and aluminum or rubber spacer
also what is the PV restrictor do? its sold from racer walsh and involves using a tap and drill bit? where exactly does it go and is it hard pricesion work? Will my car overheat with a Holley and is it fine for a standard transmission
