Date: 02/05/2017 09:45 am
72 PINTO WAGON
Date: 09/23/2018 06:16 pm
78 pinto wagon
Date: 03/03/2020 01:07 pm
1974 Pinto Door Handles
Date: 03/07/2017 04:06 pm
Date: 11/05/2016 09:03 pm
2.3 turbo intake (lower)
Date: 07/15/2020 09:29 pm
1979 hatch needed
Date: 05/13/2018 08:52 pm
1971 Pinto (survivor)
Date: 05/15/2022 04:42 pm
Date: 10/24/2018 07:41 am
  • Online today: 1,044
  • Guests: 934
  • Total: 934
How much Cam
Started by STREETREBEL, October 08, 2012, 10:56:50 AM
STREETREBEL
racer99
Installing the cam advanced,straight up, or retarded will
also change P to V clearances.
Intake valve diameter is also part of the equasion.
1.94 will clear where a 2.02,2.05,2.08 wont.
We have used .530 lift with stock diameter intakes
but it wouldnt clear with a 2.02 unless we advanced the cam
to get the int valve to chase the piston down the bore.
I would use .500-.510 for a standard but thats depends how much clearance
you feel safe with.
Check with Crane or Summitt they have people who can answer that question in real time over the phone...
STREETREBEL
I will order springs with the cam kit.
I will measure pushrod length when I install the new heads.
Don't need vacuum for anything.
I wanted to know how much lift I can use with the stock stroke and pistons.
racer99
You need to worry about other things also.
Coil bind,pushrod length,P to V clearance,
idle vacuum(if pb),adding a vacuum resv.
rocker arm pattern on valve tips,blah,blah,blah.
STREETREBEL
I have a 1991 "mexican" block 5.0 running engine.
I want to put aluminum heads and a bigger cam in it.
How Big can I go without hitting the pistons?
X cam?
