1976 Ford Pinto Pony
Date: 09/06/2018 05:40 pm
Date: 07/17/2018 09:22 pm
V8 rear end
Date: 04/12/2018 10:57 am
Date: 03/25/2019 09:02 pm
Date: 08/17/2022 06:27 pm
Date: 07/20/2018 03:00 pm
Clutch pedal needed
Date: 01/11/2024 06:31 am
76 Pinto Wagon
Date: 07/08/2020 05:44 pm
Date: 04/07/2021 06:12 pm
  • Online today: 1,492
  • Guests: 1152
  • Total: 1152
auto trans question
Started by Pup70, October 03, 2012, 08:24:58 PM
Pup70
thanx for all the info now my next question dose any one have one for sale
DreamBean
Great Info! Thanks everyone.
Go Ford, Go Fast Or Go Home!
fast64ranchero
I have one, and as stated above, the early stock units, not to strong, but if you use the right parts, you won't have to worry about breaking them...   It's the same basic tranny as used in the Mustang GT through 2010, they just made changes along the way including making them all electronic controlled, but the guts interchange, or atleast most of them...
Mine has a 95 Explorer case, early valve body to keep it manual shift, it has all the guts from 4r55 and 5r55 making it completely rollerized, 5 and 6 clutch drums, a double disc lockup convertor, and a bellhousing from a 2000 ranger..
My thought is, if it can hold up to a 3,800lb Mustang, it'll hold up to my 2,200lb Pinto with the same power....
People use to say the C-4 was weak and talked up the C-6
72 old V-8 parts Pinto
73 pinto, the nice one...
racer99
An A4LD is basically a C3 with overdrive.
They are not very strong.
i have yet to get my hands on one so i have no idea of how much space it needs...
johnbigman2011
Now that is interesting. Paddle shifters???? Would you have to do allot of trans tunnel mods as well?
ford detuned the automatic turbocoupes to 155 hp due to the lack of strength of a stock a4ld..... yes there are kits and all for them but they do not hold up to abuse... if you want to have a strong auto overdrive tranny there are a few who are using a 4r55 and the 5r55 tranny from an explorer........ explorer forums has a great writeup on this swap..... the 4 or 5r55 with the removable bell uses the bell ( with slight modification) and plate from a 4r44 bolted to it.... this allows it to be a direct bolt on to the 2.3... but...... you will need a controler for the selenoids... its not a cheap swap but a great one if you want a strong overdrive auto.....plus you can do cool stuff with this tranny like paddle shifters.....hmmmmm...
johnbigman2011
yes, the a4ld from a 87-88 thunderbird turbocoupe will bolt right up...
waldo786
I'm not entirely sure, but I think this trans would bolt up: the A4LD.  I would like to do more research on this myself, but here is some info on it from Wikipedia. http://en.wikipedia.org/wiki/Ford_C3_transmission
Pup70
i have a 77 pinto cruiser wagon 2.3 with an automatic.  My question is there an automatic overdrive trans that will bolt up to my stock motor i need to get my rpms down on the highway.
Thanx
