1978 hatch back
Date: 11/29/2019 03:18 pm
A.c. alternator hrackets
Date: 09/03/2017 12:11 pm
74 Wagon Interior
Date: 01/22/2017 06:38 pm
Date: 07/01/2019 03:17 pm
Wagon hatch letters
Date: 12/31/2023 04:24 pm
Date: 02/28/2018 09:18 am
78-80 Windshield
Date: 10/29/2021 03:11 pm
Gas Tank Sending Unit
Date: 05/22/2018 02:17 pm
parts needed
Date: 02/20/2017 07:58 am
  • Online today: 367
  • Guests: 416
  • Total: 416
Alternator
Started by delizious, August 29, 2012, 06:43:00 PM
Clean & tighten ALL battery connections, grounds, starter & solenoid positive connections & see what that does. You have a bad connection or corrosion somewhere.
I've run as much as 2200 watts, 4 subs, 6 midrange & tweets off a stock GM alternator & 1000 amp battery & never had issues. If your lights dim with heavy bass thumps try a 1/2 Farad cap wired to the amp.
Quote from: delizious on August 29, 2012, 09:38:35 PM
The starter is the square thing or the cylinder thing? The electrical box is square right? I just replaced that about a year ago.. I'm really bad with electrical systems >.<
The starter is a motor that actually cranks over the engine & is mounted on the passenger side of the engine at the transmission on the 2.3s. There is also a cable that goes from the starter, to the solenoid. If that cable is bad you could experience some issues.
"I just replaced the positive battery wire and solenoid and bought a new battery."  Do not forget the negative battery cable and its connections.  Since the components are in series, any one could cause excessive voltage drop (like weak link in chain syndrome).
Just guessing, the square thing could be the voltage regulator (bolted on the sheet metal).  If the cylinder thing is bolted low on the bellhousing, that would be the starter.
delizious
Lost 1972 Ford Pinto
Gained 1978 Ford Pinto
Quote from: delizious on August 29, 2012, 09:11:46 PM
I just replaced the positive battery wire and solenoid and bought a new battery. -.-
Is the starter bad?
delizious
Quote from: delizious on August 29, 2012, 08:56:24 PM
Yea sounds about right, but what I don't get right now is why my car isn't turning over at all it just clicks from the solenoid from time to time. Maybe a loose wire of some sort..
Sounds like your right on track with a loose or corroded wire. could be a bad solenoid too though.
http://chrisb.users.superford.org/Bronco/Projects/3G_Alternator/3G_Alternator.html
That's a pretty good write up on a 3g install
delizious
You will need to install a larger alternator not more batteries. Search for 3g alternator install they make a 130amp that can easily be found in salvage yards for cheap. And the work needed to install one isnt too complicated.
delizious
So I recently bought a 500 watt amp and didn't realize that my alternator couldn't handle it, I'm assuming I have to either totally change the charging system OR install two or more batteries? I don't know how to approach this situation I'm really bad with electrical stuffs.
