Date: 08/26/2018 06:35 pm
Need 2.3 timing cover
Date: 08/10/2018 11:41 am
1978 Pinto Wagon V8
Date: 04/28/2023 03:26 pm
Date: 10/24/2018 07:35 am
Crane Cam
Date: 02/26/2018 07:50 am
Date: 02/21/2022 11:11 pm
$300 Pinto for sale
Date: 04/19/2017 10:24 am
Date: 02/28/2018 09:33 am
Date: 04/24/2018 11:45 am
  • Online today: 531
  • Guests: 334
  • Total: 334
Pinto Camshaft
Started by Runabout80, May 20, 2005, 03:36:47 PM
Runabout80
Well that does sound much easier and cheaper to do... I'll have to check that out, how much do you think a new set of followers would cost me?
1980 Pinto 2.3, Not much now but looking at a 400+HP 302 V8 heart transplant. In 2006 probably, too hard to afford stuff like that in College.
dirt track demon
Lift at Cam is .244 Intake and Exhaust and .415 at the valves for the Crane piece I was looking at.
Those figure will only work with 1.7 rockers, not the 1.6's your pinto probably came with.
with a .244 grind your only.0003 bigger. be cheaper just to but a set of 1.7's and use your old cam.
Fomoco's biggest achievement:
The PINTO!!
Fomoco's biggest mistake:
Runabout80
Yeah, I think my cheap 2.3L top end build up might turn into something a little more.
Might use my 2.3 head and try some pocket porting and gasket matching tips my roommate taught me. But if I can leave the bottom end alone with a new cam and some head work, I could probably hit a nice HP number to let me have some fun while I build my nice 302.
H-270 Cam Grind
dirt track demon
Good luck, whatever you do though dont use the old followers on a new cam.  The lift on the cam you are looking at, are they giving you the figures for the lift at lobe height or valve lift? the figure i gave you is the actual height of the cam lobe itself, not how far the valve lifts.
Some companies use actual valve movement which is the lobe height multiplied by the rocker or follower figure, ( 1.5, 1.6, 1.7 etc.)
  So .2437 lobe height times  a 1.6 follower = .38992 lift at the valve.   if your figures on the new cam are valve height you aren't getting that much bigger of a cam.
  You should be able to go upto a .480 to .500 lift, without doing a bunch of mods,  but you should go with stiffer valve springs on any cam upgrade.  Whoever you buy the cam from should be able to tell you what springs you would need.
  Hope this helps.
The PINTO!!
tim1223
Let us know how the cam works out for you.  Will that cam work without doing any mod???  If it works for you I would like to put one in my stock 2.3.                    THANKS TIM ;D
Runabout80
Thanks, looks like my perspective cams are quite an upgrade... All with a lift of .404" and .420" should be a fun build with my old 2.3L
dirt track demon
Lobe lift is .2437  i dont have the figures on duration at the moment they are in another book.
The PINTO!!
Runabout80
Well, I was wondering if anyone out there might know the lift and duration for the stock 2.3L cam?
I want to do a little baseline comparison between stock and a couple of other camshafts I found for sale in the Ford Racing Parts webcatalog.
