Date: 01/28/2019 05:15 pm
Date: 12/10/2016 04:11 pm
rear hatch back louvers
Date: 04/18/2017 12:44 pm
Date: 08/03/2017 07:40 pm
Date: 05/03/2024 05:37 am
72 Pinto parts
Date: 12/04/2018 09:56 pm
Date: 10/10/2019 10:02 pm
1978 hatch back
Date: 11/29/2019 03:18 pm
2.3 pinto carb
Date: 08/18/2018 02:07 pm
  • Online today: 122
  • Guests: 131
  • Total: 131
help, what is this??
Started by waldo786, July 31, 2012, 10:57:36 PM
78_starsky
"while I have the whole thing torn apart it would be easy now to pull it out"
true however, if you pull it out and don't replace it or plumb for it and need it you will need to tear it all apart again to redo it.  easier to plumb for it and hook it up in the future if you want it.  it has nothing to do with your motor. it is to exhaust gasoline vapour fumes from the gas tank.
cheers
waldo786
Well the motor I'm planning on putting in there is going to be a much newer version, such as a 2.3L Duratec out of a 01-11 Ranger, so I figure that filter wouldn't apply.  Just figured while I have the whole thing torn apart it would be easy now to pull it out.  I did look at that link it was interesting so thanks for sharing - never knew about them before.
78_starsky
hi,  the new(er) motor won't come with one (if it does i would be extremely surprised)  just leave it where it is and plumb into it with the new motor. you should keep it (choice is yours) and do you live where they run for emissions?.  Your car might not pass if you don't have it hooked up.  the post i linked to explains what it does and how it works on cars. (yes it was a newer link to toyotas, however, same principals at work.)
cheers
waldo786
Interesting.  So next question - I'm planning on switching out my engine for a newer one (this one just doesn't seem to run right and hasn't for a few years).  Do I still need this?  It seems newer cars have these as well in the very quick research I did so I'm assuming I would use the one that comes with the new motor?
mrskydog
That is a Fuel Vapor Storage Canister.
Part# E5TZ-9D653-A
KIRK
"Living the Dream...Driving Old Fords"
1965 Mustang 2+2 Fastback
1980 Pinto Rallye 32,000 Org.
1972 Maverick Grabber V-8 car
2005 Mustang
I thought those were all up front behind the drivers side headlight.....
78_starsky
waldo786
So I was working on my Pinto today and got the fender off.  I could see this threw the crack, but now I can see all of it now that the fender is off, but what is this?  One of the tubes goes to the air cleaner, the other I couldn't exactly tell.  Any help would be appreciated!
