Parting out 77 Bobcat Hatch
Date: 11/06/2017 04:16 pm
Hood Hinge rubber boots
Date: 09/28/2018 05:49 pm
Date: 12/09/2018 06:59 am
Date: 02/21/2017 06:29 am
Date: 08/08/2017 01:44 pm
Clutch Cable Needed
Date: 04/03/2017 10:54 pm
Date: 01/28/2017 12:30 pm
Date: 09/01/2017 07:52 am
Mustang II V8 swap parts
Date: 03/26/2017 02:25 pm
  • Online today: 169
  • Guests: 145
  • Total: 145
Rag Joint Steering replacement
Started by mrskydog, July 21, 2012, 07:24:18 PM
mrskydog
OK... 1st of all the car needs to be off the ground, ramps lift etc. The proper Part number for this is: Help Line Dorman Part# 31000. This Rag Joint is 2-1/4 inches
center bolt hole to bolt hole.  #1 remove coupler bolts at shaft. #2 remove upper shaft bolt at firewall. #3 Tap coupler at rack spline to loosen off shaft. #4 spray shaft upper with a good penetrating oil at slip spline. #5 sometimes need to tap upper shaft out of slip spline. see pictures of spline in vise,take car to mark your steering shaft ,have wheels straight. Drill out the 2 riveted post from lower coupler( in picture ) Bolt on Dorman Kit #31000 has instructions ,reused hardware with new bolts. #6 Loosen Rack front 2 bolts, and move rack forward to allow rebuilt shaft room to reinstall. #7 please note that the upper shaft at the firewall is (u-shaped) on on side at the end and must be installed matching this way. #8 Make sure to clean and lube shaft upper ,and lower rack spline. #8 Line up re tighten 2-rack bolts ,then all others. Drives like New! Hope this helps.....Kirk
"Living the Dream...Driving Old Fords"
1965 Mustang 2+2 Fastback
1980 Pinto Rallye 32,000 Org.
1972 Maverick Grabber V-8 car
2005 Mustang
mrskydog
2005 Mustang
mrskydog
Today I tackled the steering Rag Joint.
The ones on 79-80 were plastic and fall apart, bad design. Mine fell apart after 30 plus years. Took a total of about 3 hrs, I took my time. I will post pictures first, then I will follow up with what had to be done.
2005 Mustang
