Date: 06/28/2019 09:14 pm
1980 Pinto Wagon
Date: 02/29/2020 07:01 pm
Date: 08/05/2018 01:58 pm
Early 2.0 engines
Date: 05/09/2018 12:45 pm
Date: 02/10/2017 09:30 am
Date: 03/17/2019 10:15 pm
Date: 06/25/2021 12:59 am
Radiator
Date: 05/27/2018 06:07 am
Date: 01/18/2017 05:35 pm
  • Online today: 1,972
  • Guests: 135
  • Total: 135
2.0 head rebuild or can I just swap it?
Started by pintobean74, July 09, 2012, 03:49:48 PM
NMPinto
Sure, you could just swap it as long as the replacement head is in really good shape, otherwise you would just end up doing it again. If the replacement head has been rebuilt or at least well inspected then your good.
I had my 72 head rebuilt with new exhaust seats, all 8 valves and valve guides, new cam shaft bearings. Inspect
the cam journals to be sure they are still within spec too. It was well worth the $400 or so duckets for the machine
work and parts because the engine runs great now and only have to be concerned about adjusting the valves
every 20 to 30 thousand miles or so. Also don't forget to check the head for warping and look real close at the freeze plugs too.
71 Brown Runabout 2.0/C4 auto - Mom bought new in 71.
72 Green Runabout 2.0/4 speed - Restored to original.
96 F-250 7.3L Turbo Diesel - Big White Truck!
pintobean74
Hello, I have a '74 pinto 2.0 L engine, the overhead cam has froze up, does not crank. I don't know much about engines, so I have a question, instead of a rebuilt head can I just swap another working head in it's place, is that possible? Any help would be great. Thanks
