Date: 12/09/2016 08:34 am
2.3 turbo intake (lower)
Date: 07/15/2020 09:29 pm
Date: 11/08/2020 02:10 pm
I need a 1976 hood
Date: 12/19/2016 06:02 pm
Date: 02/05/2020 11:06 am
Date: 04/07/2021 06:12 pm
71 72 front bumper brackets
Date: 06/10/2020 10:55 am
Parts for 74 Squire Wagon
Date: 09/16/2019 07:35 pm
Pinto for sale
Date: 04/19/2017 10:15 am
  • Online today: 321
  • Guests: 413
  • Total: 413
hatchback vs wagon carpets?
Started by waldo786, June 29, 2012, 11:34:36 AM
waldo786
I stand corrected, good find Mike!
waldo786
That's exactly where I got mine from as well.  It was $150 shipped here - they happened to have one on ebay for my year.  They have some on there now but not for all years.  Their screen name is adealsap there at ebay.
bbobcat75
got mine and a buddies from acc they are the best in the biz and you get what you pay for!!! great quality and fit!!
just my 2 cents
1975 mercury bobcat 2.8 auto
FlyerPinto
Waldo,
If you don't mind my asking, where did you get your carpet? I need to put new carpet in both of my cars and yours looks really great.
Thanks,
Matthew
aka FlyerPinto
1977 Bobcat HB
1977 Bobcat HB
1978 Pinto Cruising Wagon
johnbigman2011
Nice JOB Waldo.. Looks like a new car.
waldo786
sedandelivery
waldo786
Finally got pics of the carpet.  Seems really nice - I like it.
waldo786
The pic is generic, it is a one piece carpet.  it fits pretty nice I have to say.  I almost finished getting everything buttoned back up inside, I will hopefully be able to post some pics tomorrow after it is all done.
blink77
Was it one piece or is the pic just generic?
waldo786
Mine seems nice.  Haven't quite got it everything all bolted down on it but it definitely seems like it will be enough to cover the sill plates.  I got it on ebay from ACC.  Here is a link, I'm sure they have more for sale on there if anyone is looking for a carpet.  http://www.ebay.com/itm/400294989642?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649.  I'll post pics soon when I have it all installed.
sedandelivery
I just put a new carpet in my Sedandelivery. Looks great but the ends do not cover the sill plates, I had to use extra carpet to cover them. Make sure you buy a quality carpet! The effort is worth it
waldo786
First, sweet pinto in your signature!  I really like that color combo.  I did closely what you mentioned when I started installing today.  I didn't totally remove the shifter and parking brake.  I measured from the bottom of the sound deadening in the middle coming down from the firewall to the first cut for the shifter in the sound deadener (the piece that is the middle that covers around both the shifter and the parking brake).  I then took the sound deadener and placed it over my carpet and at 23 inches made a much smaller holes to just get over both the shifter and the parking brake.  It seemed to work pretty well.  After that I just kept making small cuts to fit the carpet in starting with lining up the back.  I trimmed some parts in the front to make it fit under the console, which I took out.  I'll hopefully have some pictures up in the next few days.  Good luck with yours!  And don't feel bad, I've gone through many replacement parts restoring my Mustang - just part of the learning process it seems.  Lol, seeing Eric's post, I guess there's more than one way to skin a cat.
bbobcat75
started mine by removing all as said above shifter and e brake handle and radio and center console. then put under dash as far as factory then worked my way back, buddy at the interior shop told me to start from the front firewall to the rear floor pans for best results.  hope this helps
eric
Mike Modified
Quote from: waldo786 on July 20, 2012, 07:47:49 PM
Thanks, I did get order the carpet and definitely will fit.  Just have to cut all the holes which is a pain considering I threw away the old one.  Doh!  Won't do that again!
The carpet I bought was grossly oversized and I had also thrown away my old rotted carpet.  Guessing as to where the carpet should fit, I totally screwed it up and will soon be buying a new one.
Hint of the day: remove the shifter from the transmission and the parking brake, then fit the carpet to the floorpan for the fewest lumps probably starting in the rear footwell.  After you've got the best possible fit, THEN start cutting holes (and trimming edges).
bbobcat75
you are better off to set ne new one in and cut a little hole where you need it and go from there, trying to use an old on for a templet is a pain and usally ened up cutting a hole in the wrong spot or too big, did this on my wagon 3 months ago.
just my 2cents
waldo786
qikpnto
If I remember correctly the passenger comparments on the station wagon and hatch back are all the same and I know they sell them as such.
77 V8 Cruzin Wagon Custom
waldo786
I have my '76 Wagon pulled apart inside and removed the old carpet.  I was wondering, the carpet kits you see for the hatchback cars, are the passenger areas the same size, or will I need a different carpet?  I had one place tell me they can leave a hatchback carpet untrimmed in the back for an extra 5-7 inches if I need to.  Any enlightenment on the matter would be greatly appreciated.
